Sponsored by: CARiD
Drive train stutter
Old Nov 17, 2008 | 09:50 AM
woodendude's Avatar
Drive train stutter
Over the last couple of days I've developed and stutter when taking off from a stop and then it turns into a rumbling vibration at driving speed. It doesn't shake the steering wheel at all but you can feel it in the floor and all over I guess. I'm thinking maybe a u joint, so I greased them up today but it made no difference. Tranny, front/ rear diff oils have been changed with in the last month so I'm thinking that shouldn't be it. Nothing changed on the truck either, as in parts added or work done to cause it. Any ideas?
91 4Runner, 3.0, auto.
Derek
Old Nov 17, 2008 | 09:53 AM
DeathCougar's Avatar
Torque converter chatter, sounds like to me. Perhaps slippage in the trans? Either way, sounds like a trans problem from the symptoms you describe.
Old Nov 17, 2008 | 09:58 AM
woodendude's Avatar
Not good !!!
I should add that the rumbling goes away when I let off the gas and coast while driving.
Old Nov 17, 2008 | 04:59 PM
woodendude's Avatar
I don't know much about trannies, if it is the torque converter is this replacable, or should I be looking for a used tranny?
Old Dec 5, 2008 | 12:44 PM
woodendude's Avatar
Have had the truck on blocks for a week and a bit now to put my lift on and got to checking the u joints and a rear u joint was bad. Replaced it and the stuttering , shake is gone.
Old Dec 5, 2008 | 06:38 PM
FredTJ's Avatar
That's actually a pretty rare thing...
Fred
Old Dec 6, 2008 | 04:25 PM
abecedarian's Avatar
vibrations which appear while accelerating and disappear when you let off the throttle are often drive-line related: somewhere between the output of the trans (xfer case) and the rear differential (assuming the vibe occurs when not using 4wd).
U-joints are a common wear item and should always be among the first things checked when there's a vibration when driving.
glad to hear things are fine now.
keep an eye on the rear differential for any leaks since a bad u-joint back there can pound on the pinion and cause the seal to wear.
Old Dec 6, 2008 | 04:43 PM
woodendude's Avatar
Thanks for the heads up on that!
Old Dec 6, 2008 | 04:47 PM
you're welcome.
and we have a forum specifically for 86-95 trucks and 4Runners
https://www.yotatech.com/f116
jasonty
41
Dec 23, 2018 01:00 PM
Tykiller1994
Aug 10, 2015 07:49 PM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
