Sponsored by: CARiD
Does anyone know what this part is called
Old Oct 30, 2015 | 09:40 AM
acamacho37's Avatar
I have a 22r 91 Toyota Pickup. I suddenly saw this missing, but I dont know the specific name for this part. I appreciate everyones help!
Attached Thumbnails Does anyone know what this part is called-screenshot_2015-10-30-10-22-10.png
Old Oct 30, 2015 | 04:31 PM
Terrys87's Avatar
I don't know the correct name for it but I think if your truck does not have AC, you will not have it if I am correct on that.
Old Oct 30, 2015 | 07:12 PM
acamacho37's Avatar
My truck has AC and it still works with out that spring thing. I have seen it before in my engine but i never thought that it would fall out of place. Now im trying to replace but I can not figure out the name of it, thanks for the help though! By the way, i have moved that spring before and it would change my idle to high or low, depending on how you would rotate it.
Old Oct 31, 2015 | 11:15 AM
wyoming9's Avatar
Red face
Now I am not sure just what year the were no longer used.
You would have a fitting on the pump if you need one
Screwed into the pump with two nipples
But it is the valve for the power steering pump
One line goes over to the power steering pump the other one comes off the manifold I did not look just where.
If it came off it would be hanging there some place .
Old Nov 2, 2015 | 06:26 PM
maco35's Avatar
A/C idle up valve. Is used to bump the engine idle when the a/c is on if idle is too low.
Old Nov 2, 2015 | 06:30 PM
maco35's Avatar
http://www.4crawler.com/4x4/CheapTri...ne_Pix/13.html
Old Nov 4, 2015 | 08:29 AM
acamacho37's Avatar
Thank you guys alot! So it is called the A/C Idle Set Screw, now to find that part and replace it asap because its idling up and down like crazy haha
Old Nov 4, 2015 | 09:12 AM
acamacho37's Avatar
By any chance, does anyone know where i can get the A/C idle up Adjustment screw part on the internet besides junkyards?
Old Nov 5, 2015 | 05:42 AM
maco35's Avatar
Ebay or check the classifieds section on here for cars parting out.
Old Nov 5, 2015 | 05:43 AM
maco35's Avatar
https://www.yotatech.com/forums/f91/
SpcNemo
11
Mar 15, 2016 12:21 PM
BigO
Nov 4, 2015 10:40 AM
4x4 goo roo
Oct 25, 2015 12:13 AM
rick8282
Oct 24, 2015 06:21 PM
ToyotaMD
Oct 23, 2015 10:37 AM
