Sponsored by: CARiD
Cranking the torsion bars?
Old Jan 16, 2006 | 12:33 AM
Zenkai's Avatar
Whats this cranking of the torsion bars that Ive read about to gain lift?
Noob question I know.
Old Jan 16, 2006 | 02:49 AM
Buck01's Avatar
torsion bars are used instead of leaf or coil springs. They can be adjusted (cranked) up or down. This changes the ride hieght of the front end of your truck. Also the harshness of the ride from my experience.
This is usually done to raise the truck up to fit bigger tires.
Old Jan 16, 2006 | 06:17 AM
mt_goat's Avatar
Looky looky:http://www.off-road.com/toyota/tech/torsion/index.htm
Old Jan 16, 2006 | 11:10 AM
tc's Avatar
tc
Note: an alignment is necessary after doing it! It throws the camber all out of whack!
Old Jan 17, 2006 | 02:03 AM
Zenkai's Avatar
Awesome, thanks guys.
Old Jan 19, 2006 | 10:40 AM
JonathanG32's Avatar
if your thinking of cranking them up dont because mine were cranked all the way when i bought it ant the ride sucked and i tocv boots all the time and it was hard to change them
Old Jan 19, 2006 | 01:27 PM
4Crawler's Avatar
Here is a write-up on the topic:
Old Jan 19, 2006 | 02:02 PM
Epic Ed's Avatar
It's a good way to gain an inch or two on 2nd gen 4Runners. Beyond that, you run into CV joint issues (if you don't have manually locking hubs). You will sacrifice a little ride quality but not much at that height. YMMV.
Ed
andrewtexas123
Jul 6, 2016 01:49 AM
89fourrunner
Feb 17, 2016 06:52 AM
Steven.m.paulk
Aug 16, 2015 04:52 AM
mavenator
Aug 13, 2015 01:12 AM
coffey50
Jul 28, 2015 10:55 AM
