Sponsored by: CARiD
Correct value of MAF at idle on 2008 4Runner 4.0
Old Sep 25, 2018 | 06:03 PM
UberSuper's Avatar
Hi
what is the correct spec for MAF reading at idle?
i am getting 6.8 gram per minute at idle when starting cold.
Freeze Frame DTC: P050B
Fuel System Status: Closed loop, using oxygen sensor feedback to determine fuel mix
Calculated engine load value: 38.0392156862745 %
Engine coolant temperature: 59 ℃
Short term fuel % trim - Bank 1: -4.6875 %
Long term fuel % trim - Bank 1: -1.5625 %
Short term fuel % trim - Bank 2: -3.90625 %
Long term fuel % trim - Bank 2: 3.125 %
Engine RPM: 705 rpm
Vehicle speed: 0 km/h
Timing advance: 13 °
Intake air temperature: 23 ℃
MAF air flow rate: 6.14 g/sec
Throttle position: 16 %
Oxygen sensor 2 Bank 1 Voltage: 0.78 V
Oxygen sensor 2 Bank 1 Short term fuel trim: NaN %
Oxygen sensor 2 Bank 2 Voltage: 0.78 V
Oxygen sensor 2 Bank 2 Short term fuel trim: NaN %
Run time since egine start: 00:02:34
Old Sep 27, 2018 | 08:03 AM
UberSuper's Avatar
Follow up:
I just measured the MAF value after warmed up at idle. It reports 4 grams per second vs. 6 when cold started.
I looked everywhere and couldn't find the spec value. I am just trying to get to the bottom of P050B which I thought was resolved when I cleaned up the throttle body. The car didnt throw the DTC for a few days but now came back. Based on the Toyota official troubleshooting it recommends replacing the MAF before troubleshooting further as long as STFT + LT <20. Any expert out there? Thanks in advance.
surfin cj7
Apr 2, 2012 03:35 AM
GhostriderTx
Jul 1, 2007 07:03 AM
joshg
Apr 9, 2006 05:37 PM
