Choosing wheels
Choosing wheels
Hey everybody
I been wanting to put some steel wheels with "D style spoke" on my 3rd gen runner, the stock wheel size is 16x7 and the tire size I'm running is 265/70R16. I was told something about 4runners or Toyotas being hub-centric and best suited with alloy wheels not steel wheels which I was told were lug-centric. My question is, does anyone running steel wheels have problems running steely's?
Thanks!
Thanks!
What you'll have to do is either find a set of hub rings, which I'm not sure of anyone making them, or have them balanced with an adapter. Toyota put out a service bulletin reguarding this exact issue. Most tire shops don't know this, so they balance lug centric wheels with a hub centric adapter on their balancer. I know my dealer has the adapter for our balancer. Make sure you find a shop that has one, and you'll be fine.
Exactly what I was saying. The alloys use a shank style lug nut that uses the cent hub to center the wheel. The steel wheels used acorn lug nuts, that center the wheel using the lug nuts and studs. That's the reason behind the service bulletin I mentioned in my last post.
Sorry, I should've mention the wheel I wanted were to be offset. The stock steel wheels Toyota put out aren't offset. Obviously. Thanks.
Oh and about the lug studs, I didn't know those might have to be changed. How are the two different? Aside from the lug nuts and lugs holes on the wheels.
The studs are the same between steely's and alloys. Te difference is in the lug nuts themselves.
Here's a pretty good explanation. The steel wheels use the lug nuts on the far right, and the stock Toyota alloys use the center lug nuts.
Thanks again!
Hey everybody
Thanks!
Thanks!
You don't need new studs. Just a change of lug nuts. Different lug nuts are used for aluminum and steel wheels.
I wasn't telling him he would have problems. I was just letting him know about the issue that quite a few people have seen. I mean, if there were enough complaints that Toyota issued a service bulletin, then it was a fairly big issue.
It shouldn't be a issue at all. Wheels are wheels. Toyota lug studs are centered perfect. Therefore any 6 lug wheel that matches the bolt pattern and center bore will fit. No matter how the tires balanced it should be fine. If you use the correct lug nut with the corresponding wheel there should be no vibrations or anything.
Please correct me if I'm wrong
As for the original post.
Your steelies should fit with no problems. Make sure your tire doesn't rub the upper a-arm and use the correct lugnuts
If the backspacing isn't enough you will encounter rubbing. However a spacer will accommodate.
I only know of the few that were issued to newer trucks with TRD wheels and/or TRD brake systems.
http://www.ih8mud.com/tech/tsb/Toyot...r/tsu00296.pdf
https://www.yotatech.com/forums/f2/ballancing-problem-40204/
http://www.4runners.org/writeups/haweka/
There you go. It's been a known issue since the early '90's.
the1998sr5
27
Nov 17, 2015 09:30 AM
thzpcs
Oct 3, 2015 07:39 AM
Up&Down
Aug 5, 2015 06:20 AM
skoti89
Jul 6, 2015 07:45 PM
