Sponsored by: CARiD
a/c pulley spins when a/c is not running...
Old Jul 17, 2009 | 06:28 AM
oregon taco's Avatar
do you think i can just leave it alone? or will everything fail eventually? what about just disconnecting it. has anyone done this?
98 tacoma/130k/31" bighorns
Old Jul 17, 2009 | 06:51 AM
4Crawler's Avatar
Are you talking about the outside of the pulley? If so, that is normal, as it always turns when the engine is running. But when you turn the A/C on, then the clutch inside the pulley locks up and actually turns the compressor.
Old Jul 27, 2009 | 05:43 AM
jim'struck's Avatar
I just got an 85 4runner and it sounds like the bearing on the outer a/c pulley is starting to seize... curious if disconnecting the a/c is advisable. I live in colorado and a/c is not important to me... would more hp also.
Old Jul 27, 2009 | 05:50 AM
algranger's Avatar
It's normal for the pulley to spin in correspondence with the engine
You could remove the belt
Old Jul 27, 2009 | 06:28 AM
buckz6319's Avatar
yep... remove the belt from the AC pulley won't hurt a thing
Badlander
Oct 10, 2015 08:05 PM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
EVars
Sep 29, 2015 02:06 PM
voiddweller
Sep 28, 2015 11:21 PM
