Sponsored by: CARiD
BJ spacer confusion
Old Sep 26, 2009 | 10:58 PM
Mstrkage's Avatar
BJ spacer confusion
I am looking to lift my stock 2nd gen in the near future and am only looking to go up about 1.5in. I want to use BJ spacers but have heard that you need to use a different back space in the rims so the upper control arm wont rub on the tire, is this true? And if it makes a difference I only plan on running 33x10.5 tires
Thanks
Old Sep 27, 2009 | 07:59 AM
FredTJ's Avatar
Thanks
You should be ok with the 10.50's.
You do know that you can fit the 33 x 10.50's on your vehicle as
it sits stock height with no lift at all don't you ?
If you do the bj spacers you'll have to lift the rear, get longer shocks and should address the rear axle shift when you lift it.
If you want just a little lift then get a 1" ~ 2" bl.
The ones that poo poo the bl's simply have no idea of the advantages of a bl over a mild suspension lift.
Fred
Old Sep 27, 2009 | 04:47 PM
Mstrkage's Avatar
I really just want the BJ spacers so I can relax the torsion bars.
Thanks for the info
Old Sep 27, 2009 | 05:25 PM
Jay351's Avatar
You should be able to get away with runing stock rims and the 33x10.50" tires. You might have to grind the small lip off of the UCA but thats not a big deal..
Old Sep 27, 2009 | 05:29 PM
FredTJ's Avatar
Thanks for the info
Do you and them cranked up now ?
Fred
Old Sep 27, 2009 | 05:30 PM
4Crawler's Avatar
It is typically the 31x10.50 tires that have a clearance issue on stock wheels:
- http://www.4crawler.com/4x4/ForSale/...tml#DISCLAIMER
Comes down to where the bulge of the sidewall is with respect to the end of the UCA.
And as noted if you run into a clearance issue, you can trim back the outer lip of the UCA or add a 1/4" wheel spacer.
Old Sep 27, 2009 | 07:07 PM
Mstrkage's Avatar
awesome thanks for all the info! I guess I'll try it and then just look for rubbing
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
