Sponsored by: CARiD
Best gears for 33x12.50s?
Old Apr 26, 2011 | 12:21 PM
RogueYota's Avatar
So I have an 87 Toyota single cab short bed with a 22R. Im running 33x12.50/15 BFG KM2s on no lift but soon to do about 2-3"
What gears would be best? 4.88s or 5.29s?
Old Apr 26, 2011 | 12:50 PM
BigBluePile's Avatar
Only goooogle knows....but seriously there's a BUNCH of helpful threads...even stickied threads about gears....
Old Apr 26, 2011 | 12:57 PM
Bojangles's Avatar
Searching is your best friend.
With that being said....
If you plan on going up to 35's or bigger, run 5.29's...
If your keeping 33's and no bigger, stick with 4.88's because with 5.29's you'll be running high rpms with less gas mileage.
Old Apr 26, 2011 | 01:10 PM
scuba's Avatar
5.29's and don't look back.
Old Apr 26, 2011 | 01:13 PM
Bojangles's Avatar
Depending on if your lifting and wheeling it, or lifting for looks and daily driving.
Old Apr 26, 2011 | 01:22 PM
xxxtreme22r's Avatar
or 5.29's if your an auto trans and 4.88's if your a manual.
Old Apr 26, 2011 | 01:44 PM
sebastianholmes's Avatar
X's 2
Old Apr 26, 2011 | 02:01 PM
RogueYota's Avatar
Im lifting for tire clearance. Wheeled not too often and its a daily driver. Also a 5spd.
Old Apr 26, 2011 | 02:08 PM
RogueYota's Avatar
When you do the rear you need to do the front too right?
Old Apr 26, 2011 | 02:14 PM
RogueYota's Avatar
Also where can I find a set? I found a few websites that sell rears but not fronts...then sites that sell both but no prices.
Old Apr 26, 2011 | 02:17 PM
WD_40's Avatar
Yes, both the front and the rear diffs need to be the same gear ratio. If they're not your drive train will bind when you engage 4WD because the front wheels will be turning at a different ratio than the rears.
Old Apr 26, 2011 | 02:26 PM
RogueYota's Avatar
ok....I can find rear ring a pinion sets all over the place but cant track down a front set.
Old Apr 26, 2011 | 02:34 PM
scuba's Avatar
you can buy complete built diffs from these guys:
http://eastcoastgearsupply.com/c-616...rs-toyota.html
Old Apr 26, 2011 | 02:40 PM
RogueYota's Avatar
Those 8" ring and pinion sets....will they fit front too? Cause I can only find FJ and 05+ IFS sets.
Old Apr 26, 2011 | 02:52 PM
scuba's Avatar
This is what you will want for the front end.
http://eastcoastgearsupply.com/c-616...oyota-7-5.html
Old Apr 26, 2011 | 02:57 PM
RogueYota's Avatar
ok sweet....thank you! I know I know lol
Old Apr 27, 2011 | 10:37 AM
Bunch of damn spoooon feeders......
Old Apr 27, 2011 | 10:40 AM
scuba's Avatar
post ho.
Old Apr 27, 2011 | 10:43 AM
post ho.
hippy.
Old Apr 27, 2011 | 12:14 PM
jlshaff9's Avatar
Like you, mine's a 5 speed and daily driver. I take it for the occasional offroad trip, but NOT a rock crawler. I installed 4.88's to turn my 33x12.50's and am very pleased. Would definitely do the same again.
Bojangles is right on. If you're not rock crawling, you don't need 5.29 gears
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
