ball joint spacers?
AH Willkommen.............Its the loss of droop, that screws up flex.BJS and crank will not help. what size tires do you have? Spend money on lockers and keep susp near stock. hat year truck> More info.
Ball joint spacers will increase the flex given the torsion bars are set soft enough to allow for the full travel. Why? They increase the vertical separation between the bump stocks on the control arm and the contact points:
- http://www.4crawler.com/4x4/ForSale/...er.shtml#FAQ10
im runnin 31x10.50. im not concerned with the ride quality on the street, i just want some more flex, im a single father so money isnt easy thats why i was lookin into these bj spacers, so by relaxin the t bars a little, i will get a little more movement?
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
Yes, the spacers will give you some lift so you can turn the torsion bars back down to retain your current ride height and with the relaxed bar, the suspension is softer and can move easier.
Some shock part numbers below:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ1
Sorry to thread jack, but I have a question. I had my torsion bars cranked to over level, not on bumpstops though, anyway, when I got an alignment, they guy had to decrank the bars to even get close. When I realized this, I asked him to stop, and align it as close as he could. Well it's better than it was, but it's not what it should be. Anyway, my question is, can buy a 1" BJS, and decrank my torsion bars quite a bit so that they can align my front end(camber) perfectly, or as close as possible.
Thanks
Thanks
Probably depends on what the cause of the alignment problem was. If you have some damage up front to where the adjusting cams are at their limits at stock height, then any sort of lift over that may push them past their limit. If the alignment issue was simply the guy not knowing what he was doing, then the spacers or torsion bar lift would be no different as far as alignment goes. Might try a different shop and see if you get the same results.
I got the bjs installed, but it was hell. My driver side shock bolt was stripped, and my cv boot tore, but other than that i love it. Any other things i schould do now? As far as suspension goes
well a panhard drop bracket is for the rear.....idk why you would want one if you didnt do anything to the rear???
manual hubs will prolong the life of your hubs and decrease the rotating mass under your truck..thus "in theory" you should net a bit more (very small amount) of pep and gas mileage increase lol
