Sponsored by: CARiD
Analog clock wiring ?
Old Oct 20, 2019 | 08:48 AM
Gene Johnson's Avatar
I've an 85 C&C pickup/Dolphin RV and I want to install an analog Jaguar clock (fits the large square dash hole left of the glove box). I fpind an open 4 wire socket behind the hole, which may be for that purpose. I can't find a reference for a clock or that socket on wiring diagrams. ANyone have any experience with those?
I know I'll need alway-on power, dash lighting power, and a ground.
Old Oct 20, 2019 | 11:18 AM
RAD4Runner's Avatar
From 1988 4Runner Schematic.
Should function same but not sure about wire colors, so use a multi-meter to check each wire function.
Old Oct 21, 2019 | 06:30 PM
Thanks to RAD4Runner I got enough info to find correct color codes to finf power and ground to tap to make the Jag clock work. Hope to tap into gauge cluster illumination for the back light so it dims the same as gauges. Fits perfectly, snaps in place. May need to pull the cluster again for access (put in a 4Runner "real" gauge cluster previously)
Old Oct 22, 2019 | 02:30 AM
arlindsay1992's Avatar
I have a factory clock if you want a plug and play option.
Old Dec 20, 2019 | 09:25 AM
Tims86Toy's Avatar
Did the OEM wiring harness for the clock come in all models? I have a STD '86 I'm wanting to install a factory clock in. I thought I saw a 4-pin connector under there when I was replacing the heater control cable assembly.
Old Dec 20, 2019 | 09:42 AM
old87yota's Avatar
I am not 100% sure all models have that wiring, but I would say a large majority do have the wiring, if not all.
The connector you saw is most likely for the clock.
Old Dec 20, 2019 | 12:28 PM
RAD4Runner's Avatar
... I have a STD '86 I'm wanting to install a factory clock in. I thought I saw a 4-pin connector under there when I was replacing the heater control cable assembly.
Yes, 4 wires
Old Dec 21, 2019 | 10:08 AM
Tims86Toy's Avatar
Thanks RAD! I have the same wiring diagram but your "Wiring for Dummies" helps the electrically challenged like myself. Hopefully I can find that pin connector.
Old Dec 22, 2019 | 08:03 AM
Tims86Toy's Avatar
I found it! Some idiot (maybe the guy typing this post or the installer from Circuit City years ago ) wired the radio into the PIN connector for the clock. It was pulled down and hidden behind the radio. Once I pulled the radio I could see I have some rewiring to do. But I did test the clock and everything works. (Footnote - My '86 has a different color code scheme then the '85 Service Manual shows.)
I also found the wires for my cigarette lighter. Yeah! Now I can use my 1990's Uniden Radar Detector.
Old Oct 19, 2023 | 07:02 PM
Sacgalt916's Avatar
Toyota vintage analog clock wiring JECO
yellowtoytruck
May 7, 2018 05:38 AM
cheap-ass
Jan 10, 2014 06:42 AM
simplypv
May 2, 2007 02:29 PM
jjdeneen
Jan 31, 2003 07:58 AM
