Sponsored by: CARiD
alternator not charging battery
Old Jun 26, 2018 | 12:56 PM
jgrove2018's Avatar
1988 toyota 4runner. Battery light and break light on.
Old Jun 26, 2018 | 01:01 PM
jakey poo's Avatar
You need a new alternator
Old Jun 26, 2018 | 01:11 PM
jgrove2018's Avatar
Alternater was replaced.
Any fuses I should check?
Old Jun 26, 2018 | 01:16 PM
jakey poo's Avatar
When the alternator goes the battery light and brake light turn on by design. You can check fuses, but I doubt you'll find anything. I had the same thing happen to me when I was on a road trip, ended up swapping out alternators in a motel parking lot.
Old Jun 26, 2018 | 02:33 PM
millball's Avatar
Many alternators are scrapped when all they need are new slip-ring brushes.
Old Jun 26, 2018 | 04:06 PM
akwheeler's Avatar
Many alternators are scrapped when all they needed was a new battery, or a cable end etc.
test test test. tell us some numbers, battery voltage, with and without engine running. If you battery is toast and won't take a charge your battery light may come on also.
Old Jun 26, 2018 | 08:58 PM
old87yota's Avatar
^^^ x3 with the above.
You will want to test the circuit before firing the parts cannon at it.
Old Jun 26, 2018 | 11:26 PM
RAD4Runner's Avatar
Originally Posted by old87yota
... parts cannon...
LOL!
You can guess and throw parts at it, get lucky and fix it but it would be like being taken to a place blindfolded; you never know how you got there or how to get home, OR you can methodically inspect, check, test, measure, share with us what you see, hear, feel, smell, and be certain what is wrong, and when you fix it you know that you are replacing / fixing the correct part and that by fixing/replacing it you are sure you've solved your problem....
https://www.yotatech.com/forums/f116.../#post52401963
Old Jun 29, 2018 | 12:29 PM
jgrove2018's Avatar
Thank all of you for your comments.
Battery charging check:
1. Voltage 12.00V not running.
2. Voltage 11.84V when running. Varies 11.84 to 11.79
Old Jun 29, 2018 | 12:34 PM
RAD4Runner's Avatar
Something's wrong.
REPEAT: https://www.yotatech.com/forums/f116.../#post52401963
Sdb8100
7
Aug 30, 2021 12:24 PM
turpinr1
Jun 24, 2018 11:29 PM
Republic77
Jun 15, 2018 08:46 AM
agrout
Jun 11, 2018 12:17 PM
shauntey77
7
Jun 9, 2018 10:38 PM
