Sponsored by: CARiD
Adjusting Door
Old Mar 6, 2009 | 12:44 PM
toomster's Avatar
Adjusting Door
Hello all I have a 1990 22re 4runner, and I believe the drivers side door may have been replaced. It doesnt quite match up correctly, it misses the door latch by about a 1/2 and inch. I have heard you can put a jack under the door and just try to bend it up, or take off the quarter panel take off the hinges, and put washers between the lower hing and the frame. What is the easiest/most effective way to do this? Thanks
Old Mar 6, 2009 | 12:51 PM
rock slayer's Avatar
don't jack it up that will literally "jack up the door" you can possibly loosen the hinge bolts and do it that way make the holes bigger on the car side of the hinge enough to shift the door up and tighten it there
most likely its the lil plastec things that protect the hinge that are gone causing the door to sag (this is my problem)
Old Mar 6, 2009 | 01:17 PM
toomster's Avatar
Thanks rock slayer. If I do end up doing the holes any guesses how much I would need to drill out to get a 1/2 in on the end of the door. Conversly if I do the washers how many washers.
Thanks
Old Mar 6, 2009 | 01:23 PM
trial and error is your best bet it wont take much tho so start small
Old Mar 6, 2009 | 01:30 PM
toomster's Avatar
Good stuff. Thanks
Old Mar 6, 2009 | 01:43 PM
noprob good luck
Old Mar 7, 2009 | 09:11 AM
Jay351's Avatar
Make sure you don't have play in the lower hinge. Mine are pretty bad and thats why. Im just not really wanting to remove the stupid fender to get at the hinges
Old Mar 7, 2009 | 11:47 AM
874runner's Avatar
If you're going to do that. You might as well just cut the pins out of there and just buy or make some removable pins so you can take your doors off. =) i just have bolts in mine and they line up fine. Just a thought
Old Mar 7, 2009 | 02:37 PM
aviator's Avatar
Check out the stickies at the top of the specific forum section for your truck there is a link to an online version of the shop manual. In the body section there are specific instructions on how to adjust the door for fit problems.
They will call for some "special" tools but these are only wrenches, no need to buy them, a socket set and maybe a box end wrench are all you will need... and of course a friend to help hold the door.
You may need to get some washers as well to adjust the fit...
You can start by looking at the door as you close it and see which gaps are off at the hinge end this may give you a clue which hinge is the problem, next get you friend to gentle lift the door with it open as you look at the hinges this will provide another clue.
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
89fourrunner
Feb 17, 2016 06:52 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
