Sponsored by: CARiD
95 4runner 2wd v6 gear ratio
Old Apr 5, 2010 | 11:49 AM
mjbtaco's Avatar
Ive been searching and I keep finding stuff for the 4wd trucks.
Im running 31x10.5 r15 on my 95 2wd v6 4runner and this thing is slow.
I cant even get the damn thing passed 70 on the freeway. so my question is, what gears are in the truck and what gears should I run with these tires.
The timing was way advanced before and the truck was a bit faster and could get it passed 70mph no problem.
But now that teh timing is set correctly i lost alot of power, so i want to gain it back with some gears.
Any suggestions would be great and sorry if this has been discussed. I tried searching and didnt really come up with any sure answers.
thanks in advance
Old Apr 5, 2010 | 04:56 PM
az4x4runner's Avatar
Look at the sticker on your drivers side door jam. This page will tell you all you need to know about the diffs and tranny from the codes on that sticker.
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Apr 5, 2010 | 05:54 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
that will tell you what you had with stock tires...
you lose about 1/10 of gear per 1" you go up in tire diameter...
RobotMoose
Feb 22, 2020 07:44 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
toyotasaurus
Sep 24, 2015 03:30 PM
vikinghug
Sep 23, 2015 12:32 PM
