Sponsored by: CARiD
86 4Runner: gearing for 37" tires?
Old Oct 21, 2007 | 06:46 AM
rickybobby012889's Avatar
I have a 1986 Toyota 4Runner 22R-E EFI 5speed...I currently have 33x10.50 15 on it and it is real boggish and Ive read before you can change the gearing in it to pull any size tire..And noticed alot of rigs on here went with a 5.29 gear and what i need to know is how to find out what gears to go to with a 37 in tire ...I am sure someone has went thru this the problem is finding that person so any help will be appricated Thanks, Rick
Old Oct 21, 2007 | 08:42 AM
CyMoN's Avatar
https://www.yotatech.com/search.php
Old Oct 21, 2007 | 09:23 AM
Diesel_Freak's Avatar
Wow... Just...wow...
Old Oct 21, 2007 | 09:56 AM
thook's Avatar
Yep...just play with keywords and there's hundreds of thread about this subject. It's overwhelming how many there are, but you'll find the info already there.
Old Oct 21, 2007 | 03:29 PM
mtespey's Avatar
Hope this helps
According to the LC Engineering catalog:
stock 4;10 5speed@2300 rpm
33" w/4.88 2322 rpm
33" w/5.29 2518 rpm
35" w/5.29 2374 rpm
36" w/5.71 2491 rpm
38" w/5.71 2360 rpm
Old Oct 21, 2007 | 05:40 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/4R_TechI...tml#DiffRatios
Old Oct 23, 2007 | 04:37 PM
Thanks for all the info...You guys are like toyota dictonarys with everyones brain put together here
Old Oct 23, 2007 | 05:04 PM
Toy-SkiTzo's Avatar
my 4runner with 5.29s and 37s felt perfect the spedo was dead nuts
Old Oct 23, 2007 | 05:19 PM
Really and did you lose alot of speed going up hills and stuff and also what kind front suspension do you have IFS or straight axel swap If you have IFS what lift did you use
Old Oct 23, 2007 | 06:23 PM
tedfrk's Avatar
i would get a better clutch and heavier flywheel.plus the gears
XtraCab
Apr 12, 2020 05:25 AM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
PlayAwhile
Jul 20, 2015 11:36 AM
