Sponsored by: CARiD
84 22r to 87 22re
Old May 17, 2011 | 07:44 PM
Stevesk88's Avatar
84 22r to 87 22re
I have a donor 87 four runner with a 22re in it. I just need to know if i can convert my 84 22r into an re. Will i need the head from the 87? I've searched a ton i just can't find much on the 84 re conversions. Thanks toytech's!
Old May 17, 2011 | 07:48 PM
dropzone's Avatar
Fossilized
I am pretty sure the 84 and earlier blocks use domed pistons that will hit the head on an EFI..could be wrong but there are several threads on this....one guy was even going so far as shaving early pistons to make it work...don't think it will
why not swap the entire engine? gonna need the wiring harness, fuel tank, ECU etc anyway
algranger's Avatar
The 87 head won't go on your motor nor will the efi manifold match your 84 head.
Why not put the 87 motor in your truck.
Old May 17, 2011 | 07:50 PM
algranger's Avatar
You are correct the pistons have a large ridge near the perimeter, where as the newer ones are flat with small relief marks to clear the valves
Old May 17, 2011 | 08:01 PM
Stevesk88's Avatar
Ah man haha thats sssuuuuucks. I cant put the 87 engine in because it threw a rod! Shooot
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
