Sponsored by: CARiD
82 4x4 truck alternator wont charge battery
Old Jan 22, 2011 | 04:48 PM
rodney_stanley2003's Avatar
I just replaced the batt and I took the alternator to auto zone and got them to test it for me, it was good. but still no charge. so now I think the wiring was messed up when I got the truck. what wires do I need running from the alternator and where do they go. any other ideas as to what may be going on? thanks for reading..
Old Jan 22, 2011 | 04:50 PM
85gijunk4x4's Avatar
bad grounds, corroded wires, bad battery, maybe something is draining your battery
Old Jan 22, 2011 | 05:53 PM
flg8r22's Avatar
is this a gauge in your truck saying its not charging? or have you checked the charging system with a meter while the truck is running?
Old Jan 22, 2011 | 06:19 PM
I know better than to trust a 29 year old dash light no its the fact that the truck wont start without a jump and i took the alternator off and got it tested and its good. but as far as testing it while its on the truck and running I havent done that because I dont have a meter to test it. what kind of meter do I need?
Old Jan 22, 2011 | 06:43 PM
flg8r22's Avatar
although the alternator passed the bench test, i would check at the battery with a multimeter. should be just over 14v with the system loaded or unloaded. other issues could also be the regulator or relay. or on a positive note, could be something as simple as a loose belt? wish i could help more but im not a mechanic, but i did stay at a holiday inn express last night
Old Jan 22, 2011 | 07:39 PM
swampfox's Avatar
Have you checked the voltage regulator ?
Old Jan 27, 2011 | 06:20 AM
so now it looks like I have a starting problem. I put on a new starter, tried another battery traced down all the grounds and when I turn the key all I get is a few clicks from the starter and clicks from under the dash. I tried running a hot wire to the starter and it made a winding and clicking and it sounded better but it still wouldnt turn over. what is going on with my truck?
Old Jan 29, 2011 | 12:23 AM
wyoming9's Avatar
Red face
How does one trace the grounds?? Just what does that tell you about the condition. This grounds were poor from new.
Every Toyota I come across I make new grounds running one to the steel of the engine block the other to the body cures many starting and charging issues
The wire coming off the Alternator B terminal going to the fuse block also has a habit of dieing from old age getting so brittle it no longer conducts electrons
When you replaced the starter maybe you have a poor connection on the wire to the solenoid and the coil does not energize .
bigblue82
10
Jul 6, 2015 08:27 AM
odonekanobe
Jun 26, 2015 02:27 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
paxanders
Jun 21, 2015 06:29 AM
