5 speed transmission questions
I have a 95 4runner with a 22re engine and 5 speed manual. i need a transmission do i have to get one out of a 4runner with a 22re or will one from a 6 cyl or from a truck fit?
W56 wont work unless you get the transfercase with it, you probably have a G-series which has the chain driven case. Look in your door jam, the code for which trans you have is in it. W56 is a way better option though. And like wabbit said the R150 won't work but a R151f would.
my doorjamb says g58 is there a stamp or a tag on the transmission so if i find one i can tell what it is? i know a guy with a few transmissions out of late 80s pickups tryin to see it one of them will work, thank you for the info
I don't know about the G58 transmission, but make sure it's the right one. I've recently run into that with my W56. Turns out there's a W56-A, B,C, and D and they're not all interchangeable. Not even the dealership could tell me which one i have in my 89 pickup. All I was told was that it was a 'W series' so don't trust everything they tell you either.
And the W and G series use the same bell housing bolt pattern to the engine. They will interchange. The variances are shifter locations and positioning and possibly overall length.
But the R150 from behind a V6 will not interchange. Different bolt pattern.
I have a 90 2wd Toyota p/u with 22re engine. It currently has a four-speed manual transmission. I want to upgrade to a five-speed tranny. I've spotted what I think is a five-speed in a 2wd 94 Toyota p/u in a salvage yard. How can I determine if it is a five-speed? Are there any badges to identify it?
BeMiceElf
Oct 10, 2015 09:40 PM
will tell you more than you need to know as to what fits
