Sponsored by: CARiD
5 speed transmission questions
Old May 25, 2012 | 07:17 AM
nail bender's Avatar
I have a 95 4runner with a 22re engine and 5 speed manual. i need a transmission do i have to get one out of a 4runner with a 22re or will one from a 6 cyl or from a truck fit?
Old May 25, 2012 | 07:28 AM
waskillywabbit's Avatar
W56
No the R150 won't work.
will tell you more than you need to know as to what fits
:wabbit2:
Old May 25, 2012 | 08:47 AM
bobbybouche's Avatar
W56 wont work unless you get the transfercase with it, you probably have a G-series which has the chain driven case. Look in your door jam, the code for which trans you have is in it. W56 is a way better option though. And like wabbit said the R150 won't work but a R151f would.
Old May 25, 2012 | 08:59 AM
my doorjamb says g58 is there a stamp or a tag on the transmission so if i find one i can tell what it is? i know a guy with a few transmissions out of late 80s pickups tryin to see it one of them will work, thank you for the info
Old May 25, 2012 | 10:22 AM
SPARKS89's Avatar
I don't know about the G58 transmission, but make sure it's the right one. I've recently run into that with my W56. Turns out there's a W56-A, B,C, and D and they're not all interchangeable. Not even the dealership could tell me which one i have in my 89 pickup. All I was told was that it was a 'W series' so don't trust everything they tell you either.
Old May 25, 2012 | 10:44 AM
This might help.
http://www.4x4wire.com/toyota/faq/parts/
Old Aug 25, 2012 | 01:32 PM
Richiepadfoot's Avatar
I'm having a similar problem and I really don't know what I'm doing.
I have a 95' v6 2x2 and my auto transmission went out so now I want a manual tran and i have no clue where to start
Old Aug 25, 2012 | 02:12 PM
TrikeKid's Avatar
The G-series uses a gear drive case as well.
Old Aug 25, 2012 | 05:36 PM
rokblok's Avatar
And the W and G series use the same bell housing bolt pattern to the engine. They will interchange. The variances are shifter locations and positioning and possibly overall length.
But the R150 from behind a V6 will not interchange. Different bolt pattern.
Old Aug 25, 2012 | 05:48 PM
85TurboRunner's Avatar
I think the w56 also went forward shift t-case with the C series and later.
Old Nov 1, 2012 | 06:19 PM
Daniel Leedham's Avatar
I have a 90 2wd Toyota p/u with 22re engine. It currently has a four-speed manual transmission. I want to upgrade to a five-speed tranny. I've spotted what I think is a five-speed in a 2wd 94 Toyota p/u in a salvage yard. How can I determine if it is a five-speed? Are there any badges to identify it?
Old Nov 1, 2012 | 06:53 PM
rokblok's Avatar
Check the tag/label in the door jamb/striker area. If this is non-existent, try shifting thru the gears.
Old Dec 7, 2012 | 08:51 PM
SPARKS89's Avatar
If it's still in the truck why not just look at the gear stick knob? Does it have a 5 on it?
smthwsn357
May 1, 2024 07:28 AM
Liadrin
Apr 25, 2022 02:54 PM
BeMiceElf
Oct 10, 2015 09:40 PM
mdev126
Oct 4, 2015 04:48 AM
Liadrin
Sep 1, 2015 06:44 AM
