5.71's or 5.29's with 39.5 iroks
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
V6 chunks, Longfields and 5:71's FWIW....
I have a 1984 toy truck, I was running a 350 .60 over sbc last year and the front end held togather. Now going with a 400sbc. The motor builder says 600hp. How long will the front end hold up? Will longfields hold up? Will the rear hold up to?
i wouldnt suggest 5.71s. I had a set on an old toy i had on 44s and i couldnt keep a pinion in it because theres only one tooth at a time on the pinion grabbing the ring gear which makes it really weak.
You don't have Toyota trans gearing, but have a 200hp V6, and it doesn't like 60?
"Power output of the new LU3/LG3 engines is 180 hp (130 kW) to 200 hp (150 kW) and 245 lb·ft (332 N·m) to 260 lb·ft (353 N·m)."
Is it over revving? Revs too low?
^^ zuk is the master..
@87yota, if you break the pinion and not the ring, more than likely something is setup wrong. the ring gear has the smaller/weaker teeth. a proper setup up is where you get your durability.
