Sponsored by: CARiD
3vze or 3vzfe which one do i have
Old Feb 26, 2011 | 03:03 PM
Elcabong's Avatar
I have a 94 4runner that I am about to replace the head gaskets and water pump on, and I am unsure as to which 3.0L I have. I have seen all kind of info online about vin numbers and how to tell, but the sites just contradict eachother. I just want to make sure I follow the repair manual right according to which engine I have. The engine Any help would be much appreciated. Thanks
Old Feb 26, 2011 | 03:04 PM
crazytoyota4x4's Avatar
its probably a 3vze as the 3vzfe was found in camry's.
Old Feb 26, 2011 | 03:07 PM
dsleggett's Avatar
You can pull the plastic cover in passenger footwell, right side. That's where the ECU is, it will say engine code right on it.
Old Feb 26, 2011 | 03:28 PM
mt_goat's Avatar
The 86-95 4runners and trucks have the 3VZE or 22re. Here's the online FSM: http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Feb 26, 2011 | 03:29 PM
toyota4x4907's Avatar
3vz-e.
3vz-fe is a transverse mounted camry engine.
Old Feb 26, 2011 | 03:40 PM
Elcabong's Avatar
Thanks guys, do any of you have opinions on gasket kits. Fel pro vs. beck/arnley vs. dnj/rock?
Old Feb 26, 2011 | 03:53 PM
85gijunk4x4's Avatar
ive heard good things about fel-pro. and engnbldr is the man, great service etc. i'd order from him...
and when i got my gasket set, i found out that engnblder's gaskets are just re-packaged fel-pro's anyway!!!
Old Feb 26, 2011 | 04:13 PM
mt_goat's Avatar
With 24 valves.
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
