Sponsored by: CARiD
3/4 ton axle swap front and rear on 91 toyota
Old Oct 14, 2008 | 01:15 PM
gentry20's Avatar
Question 3/4 ton axle swap front and rear on 91 toyota
im wanting to put 3/4 ton axles under the front and rear of my stock 91 toyota pickup. what would be the easiest way and are there any major problems with this
Old Oct 14, 2008 | 02:32 PM
tc's Avatar
tc
You already have 1 ton axles, why go backwards?
Old Oct 14, 2008 | 04:29 PM
gentry20's Avatar
no they come stock with 1/2 ton
Old Oct 14, 2008 | 04:35 PM
NorCrawler's Avatar
if you want better, go dana 60 front and rear.
Old Oct 14, 2008 | 05:00 PM
yotasavg's Avatar
his truck is stock...what are guys talking about??
Old Oct 14, 2008 | 06:16 PM
tc's Avatar
tc
4WD have the 1 Ton axles stock.
2WD are 1/2 ton normally.
But, yes, if you want to upgrade, you need to go to 60's. A D44 is at best a lateral move, and realistically, a step down in strength.
Old Oct 18, 2008 | 11:56 PM
TrikeKid's Avatar
Uh, 1 ton by Toyota's standards maybe. He's talking about 3/4 ton domestic trucks, which are most commonly a D44 front and D60 or 14BSF rear.
One ton Toy rear ends are actually kind of a goofy hybrid between the 8" center and smaller, 2WD outers IIRC.
He is correct though, unless you're simply going for the added width, a 60 front is the next step up, stock to stock, a D44 and a Toyota 8" are about the same, and you can make the Toyota stuff a lot stronger for relatively cheap in comparison. If I were you, I would do the conventional SAS with a solid Toyota axle.
Old Oct 24, 2008 | 12:47 PM
awareness's Avatar
Bump.
Asked about this in another thread to no avail. I'm interested in finding an option for swapping out my rear end to match the track width of the front with T100 axles after I install a TC LT kit.
Would a T100 rear be the easiest way to go? How about a Tundra rear? What problems/difficulties can I expect? Any links? I have searched both here and on Google for this and haven't found much of anything.
Thanks.
Old Oct 24, 2008 | 02:37 PM
tc's Avatar
tc
Either a T100 or Tundra will match, but they won't be able to use your current thirdmember, which could add considerably to the cost if you have a rear locker already.
Another option would be a Diamond (or other) custom housing.
My recommendation though if you're gonna use the LT as it's intended is to install a FROR full floater kit using IFS hubs/rotors. That will match the width of the front, give you disc brakes, and provide a more robust rear axle.
Old Oct 24, 2008 | 04:25 PM
AxleIke's Avatar
If you are trying to match the front, you'll need spacers even with a taco/3rd gen rear axle and the FROR kit. FROR gets you to 63.5". Front will be 6" wider than stock at 65".
Stock difference front to rear is 59" front, 58.5" rear.
If you are okay with the difference, then the FROR kit is a great choice.
Old Oct 24, 2008 | 06:54 PM
tc's Avatar
tc
I don't think you'll ever notice a 1/4" per side ...
Old Oct 25, 2008 | 10:12 AM
awareness's Avatar
Thank-you.
I'm not locked in the front or rear. I did read an article on the floater rears and they looked nice. The minor difference in width with one of them doesn't bother me too much but what sort of cost am I looking at? $1500 for the kit plus all the extras?
Also, how exactly does installing this full floater rear increase my track width by so much? It looks nice and all, but in terms of cost would this be comparable to using a junked T100/Tundra rear?
Old Oct 25, 2008 | 03:44 PM
bigarms23's Avatar
there is nothing wrong with swaping in chevy axles for mine i used all toyota componants except for the front hanger and highsteer everything else on my 884runner is toyota
Old Oct 25, 2008 | 05:01 PM
tc's Avatar
tc
It increases the width if you use IFS hubs because they have more offset built into them.
http://www.pirate4x4.com/forum/showthread.php?t=515697
Old Oct 27, 2008 | 04:40 PM
awareness's Avatar
If I'd also replaced my fron ADD's with manual locking hubs would that affect the offset of the track widths as well?
Old Oct 27, 2008 | 04:48 PM
tc's Avatar
tc
Nope.
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
Niameyrider
Jun 25, 2015 05:50 AM
Mr.Black
Jun 21, 2015 10:17 AM
TheManOutside
Jun 18, 2015 03:32 PM
Yoda
Jun 23, 2002 09:39 AM
