Sponsored by: CARiD
3.0 swapped out - New issues with cold start and operating temp
Old Sep 13, 2013 | 07:31 AM
Dom2332's Avatar
Hi guys,
Well finally got my blown 1995 pickup 3.0 swapped out with the 1991 runner 3.0. The new issues I'm having is a cold start and operating temperature problem. At cold start(Like sitting over night or all day at work) it takes 5-6 key turns at 5-6 seconds each for it to start. And when it does it sputters and idles low(200rpm) for about 10 seconds then i tap the gas pedal and it idles fine(800-1000rpm). Then it will run good, good idle, plenty of power, no hesitation for 20-30 miles then it will start to hesitate and sputter. If I come to a stop it dies. I'll have to start and keep on the gas for it to stay on but its sputtering and rpms go up an down even when i have the pedal in the same spot. I've researched several issues here on the site ranging from ECT senor, cold start injector, timer, TPS. Just wondering what you guys think I should start with.
I do have a check engine light and I read that I can get the code if I jump E1 and TE1 in the diagnostics port and count the check engine light flashes. Is this correct?
The donor 4runner did have the operating temp idle/sputter issue before the swap but it started right up on cold start.
Thanks for any help.
Dom
Old Sep 13, 2013 | 07:09 PM
Dom2332's Avatar
Ok so I jumped te1 & e1 and got the following codes. 22 and 32
22 - engine coolant temperature sensor. So I will be replacing this tomorrow.
32 - air flow meter signal. Not sure what to check here any suggestions. Can you clean those? Could it be loose connection?
Old Sep 16, 2013 | 07:13 AM
Dom2332's Avatar
So no more codes!!! Swapped out the ECT sensor and pulled the EFI fuse and woala....no more codes. Truck starts right up now on a cold start. I'm still having the idle/rpm issue once the truck gets hot. It almost seems like its running rich when it does it. If I look at the exhaust while I give it gas to keep it on I can occasionally see puffs of black smoke coming out. Not sure what is causing this, possibly vacuum leak or something.
Crazychris1871
Jun 27, 2016 10:38 AM
Bru
Jun 23, 2015 06:58 PM
jmc88runner
Jun 18, 2015 03:39 PM
scott
Jul 15, 2002 07:56 AM
