Sponsored by: CARiD
3.0 3VZE - Strange air intake noise...with video
Old Jun 28, 2014 | 02:01 PM
cartercoulombe's Avatar
This is a 1994 Toyota Pickup 3.0 3VZE 4x4
Hey guys, so I can't figure out what this noise is, its definitely coming from the airbox. Sounds like the engine is not getting enough air to me, its a loud sucking noise. Any ideas? Even with the airbox open (no filter restriction) it makes the noise (its even louder).
On another note, it looks like the central fan belt drive has a wobble to it. Maybe its just the normal engine vibration, what do you think?
Old Jun 28, 2014 | 02:38 PM
rworegon's Avatar
It very well could be transmitted sound if the fan bracket (false water pump) bearing is shot i.e. the likely the source of the wobble if nothing is bent. The sound is metallic to my ear. Other bearings, the timing belt idler bearings and water pump. What is the timing belt/water pump history?
Also, oil level ok?
Old Jun 30, 2014 | 07:35 AM
Not actually sure of the timing belt/water pump history but the engine was rebuilt 18k miles ago, I'm hoping it was done then. Yeah oil level is good.
Just today the fan belt started squeaking on cold start up. Once the engine warmed up, the squeak went away.
And this is probably a separate issue, but on acceleration from idle the engine tends to stumble/miss/bog down if I accelerate too rapidly. Could be injectors? At higher RPMs the engine seems fine and has plenty of power.
Old Nov 8, 2022 | 09:11 AM
1994/3.slow's Avatar
Did you find a fix for this? I’m having the exact same issue. Same noise same wobble
Old Nov 27, 2022 | 04:49 AM
mydavestrong's Avatar
DrCreosote
Mar 1, 2021 07:20 AM
sharrock
Jul 19, 2015 06:22 PM
808-3VZE
Apr 22, 2013 07:27 AM
KBump
Aug 25, 2010 10:17 AM
the"RoadRunner"
Feb 16, 2007 10:26 PM
