Sponsored by: CARiD
22re fuel issues
Old Mar 26, 2016 | 07:13 PM
Rsloop90's Avatar
22re fuel issues
Just bought an 89 4x4 pickup it had two cylinders misfirring the guy said the gas tank had some trash in it not rust but that the injecters were getting stopped up... so I replaced 1 and 2 injecters misfire quit drove it around for awhile and then lost number 1 cylinder again so my question is I saw where the guy had the fuel filter zip tied to the inner fender and its supposed to be mounted on the block would that let trash into the fuel rail?
Any help would be greatly appreciated btw I only paid 900 bucks for it 176xxx miles
Old Mar 26, 2016 | 08:07 PM
crawler85's Avatar
As long as the fuel filter is connected properly to the hoses, it does not matter where it is mounted.
You need to find out what your actual fuel pressure is at right at the injectors.
This fuel gauge makes troubleshooting your fuel system a piece of cake.
http://www.lceperformance.com/Fuel-Pressure-Gauge-Kit-22RE-3VZ-EFI-p/2019128.htm
Also, gunk in the gas tank will either get caught at the fuel pump strainer or the fuel filter.
Possible that just those injectors are clogged over time, but check the pressure going to them first.
Old Mar 27, 2016 | 09:43 AM
Rsloop90's Avatar
The injecters were brand new I just put them in?
Old Mar 30, 2016 | 12:54 AM
Terrys87's Avatar
The guy you bought the truck from is correct. It is not rust in the tank even though that is what it looks like. I would go thru the entire fuel system by what you are describing. The tank may have build up in it and you may want to clean or replace the tank depending on what it looks like.
I have seen the Return lines on these trucks clogged many times. A clogged Return Line really doesn't effect a truck on how it runs but seems to me that it just puts a lot of unnecessary pressure on the fuel pump.
Have you ran any fuel cleaner into the tank? I have seen that break up the build up and it will still get by the fuel filter and clog injectors. One reason I don't recommend running fuel cleaners in a tank unless you know the condition of your tank.
Another issue with injectors not firing is the Injector Harness has some poorly designed crimps. Two injectors share the same wire. The crimps in them corrode in some cases and will not fire an injector. The crimps will pass a resistance check but not allow enough voltage to fire the injector.
In each of my builds below, usually on the first few pages, I show things on the fuel tank and how I clean them if you want to check those out.
Here is what I have found for non firing fuel injectors. Probably not your computer being at fault, but the $3 Noid light will tell you if it is sending the signal. If it is sending the signal, check the crimps.
Check your fuel system and then to see if you are getting a signal to the injectors. To test the injector, you can use the little square battery (9 volt I think it is) a syringe filled with fuel injector cleaner with a rubber hose running to the top of the injector and some pressure. Power the injector with the battery for 1-2 seconds at a time and see if it sprays fuel.
My notes for injectors>>>> https://www.yotatech.com/forums/f199...l#post51897320
Which injectors are failing? 1 and 3 or 2 and 4, that is how they operate in pairs. If the injectors are not clogged I suspect that the crimp is what is keeping them from not firing. Since the truck runs, and the other two are working, I don't think you have a fuel issue since the truck seems to be running.
To see if you are getting plenty of fuel to the fuel rail, pull the hose off of the back of the fuel rail and run it to a quart jar. With the Fuel Pump By pass jumper set, the key on, it should fill the jar in a minute or so. You will be able to tell if you are getting plenty of fuel that way.
Old Mar 30, 2016 | 03:43 AM
crawler85's Avatar
An fast injector check is to simply unplug it while the engine is running. If it runs the same, you know there is something wrong on that path and can isolate further with the above technique.
Old Mar 30, 2016 | 06:05 AM
bootscootboogie's Avatar
Subd. Good info....
Old Mar 30, 2016 | 10:05 AM
Rsloop90's Avatar
That's how I narrowed it down thank you!
Old Mar 30, 2016 | 10:06 AM
Rsloop90's Avatar
Awesome info thank you soo much I never knew you could use a 9v battery I also bought a gas tank I think that was my problem
Old Mar 30, 2016 | 12:37 PM
crawler85's Avatar
Let us know what you find, the worst thing is when these threads don't have any resolution.
Old Mar 30, 2016 | 05:03 PM
Terrys87's Avatar
I think it is in my 85 thread below some where I show how I test and clean the injector. There are some youtube videos that show some test as well.
Agree with crawler85, it is nice to see your results.
Old Apr 3, 2016 | 04:05 PM
Rsloop90's Avatar
OK so I replaced the gas tank cleaned all the lines replaced the fuel pump and strainer fuel filter injectors did cap wires plugs rotar and I have went through the timing 3 times the misfire at idle is gone it idles like a champ but when u put a load on it (try to drive it) it starts missing again it's only around 2000 rpm then clears up idk I've done everything I know to do from the previous toyota I've had any suggestions? I'd like to put it on the road this week.
Old Apr 5, 2016 | 02:02 PM
osv's Avatar
osv
my '86 had the corroded crimp in the harness, it's very difficult to troubleshoot without actually cutting into the harness to assess the condition... my engine got weaker and weaker until it died on the freeway, barely running, i had to have it towed home.
i have no idea if your '90 had the same crimp done, i would look at the wiring diagram for your year of truck and see if shows the injectors being split in pairs, like terry described.
because the reason for the crimp was to hook both pairs together in the harness, looks like it was done by the factory after the fact... these are batch-fired injectors, they all fire at once, there was never any point in splitting the injectors into pairs, unless it was some weird driver design issue in the ecu.
we are talking worst-case scenario here, you could try swapping another engine harness in first, if you have one.
even if it passes the noid test, the corroded connection may still not be able to carry enough current to fire the injector.
Oleyoter87
Jan 25, 2016 08:03 PM
Montana
Jan 21, 2016 05:00 PM
Marc P
Jan 20, 2016 12:54 PM
dlewis
11
Jan 10, 2016 05:22 PM
nekchris
Dec 31, 2015 08:16 PM
