22re complete head vs just gasket replacement?
Old 12-10-2018, 03:42 PM
retrobeast's Avatar
Question 22re complete head vs just gasket replacement?
Greetings
I have a 87 4runner with a oil leaking 22re head gasket above new timing chain / cover. With 252,000 miles on it would it make since to replace whole head vs just gasket since I can get a complete one for under $300?
Getting 22-25 highway but white smoke when starting along with a constant tick when engine runs so thinking replacing whole head which includes valves and cam may help, not to mention give some pep back to the engine.
If replacing whole head can I go for a new cast instead of an oem head? Or do new casts only come from china? which I dont want.
Happy Holidays
Retrobeast
Old 12-10-2018, 03:55 PM
millball's Avatar
Best to keep your factory head casting if corrosion issues/ crack damage do not make it un-rebuildable.
Old 12-13-2018, 06:12 AM
retrobeast's Avatar
thanks, yes head is still good, just tired.
what kind of head work might i have done or just put on new gasket and leave it at that?
Old 12-13-2018, 10:20 AM
Melrose 4r's Avatar
You would be looking at what is commonly referred to as a "valve job".
The machine shop should
hot tank or clean the head in some way
check for cracks
check head for warpage, plane it if warped
check for burned/bent valves or valve seat problems
lap the valves to ensure good seating
check valve guides, replace if necessary
check valve springs. shim to proper height or replace
replace valve seals.
The shop probably has a min charge and list of work. cost could go up depending on what is found.
Old 12-14-2018, 06:59 PM
thefishguy77's Avatar
check for cracks
If your pulling the head start here. Have you run a compression test yet? If so what are the numbers. Are your valves properly adjusted?
Maybe rings are getting worn? Bottom ends are way easier than top ends for me. To each their own.
Flip side
There are a ton of 3-400,000 mile stock OE heads still on the road with maybe 1 valve job or never having pulled the head...
92 TOY
02-16-2019 05:05 PM
FRANCOARMANI
08-02-2014 11:43 AM
Roofmaster
07-13-2012 03:54 AM
HelliphinoN8
03-14-2008 05:17 PM
rtchrg440
04-24-2007 05:12 AM
Quick Reply: 22re complete head vs just gasket replacement?
