22r burns oil on startup
Old 01-16-2013, 07:34 PM
85gijunk4x4's Avatar
I feel like I've seen these threads around before but now that I need them I cant find them.
Anyway, heres my problem. If I cold start my truck I get some pretty thick white smoke with a tint of blue and an oil smell. It only does it for a minute or two, only when cold starting, and only when its cold outside.
So whats wrong? Bad valve seals? Compression (from what I can tell) is good, havnt confirmed that with a pressure test, though. Is it coming from the rings? I changed my oil a couple months ago, cant remember wich viscosity I went with off the top of my head but probably 10w30. Seems to just start now that th temperature has dropped.
I'm not so much worried, just curious. I'll drive it until it blows up
Just wondering if Its something I'll feel like messing with.
Old 01-16-2013, 07:49 PM
cstone94's Avatar
I'd definitely suspect valve seals/guides to be worn.
Old 01-16-2013, 07:56 PM
I have a set of seals, I suppose I could put them in if I have too. Heck though, if the rings are shot I'll add oild every 500 miles until I cant afford it anymore, then take the tags off and have myself a new farm truck and run it until the motor seizes up from not having any oil
Old 01-16-2013, 07:59 PM
now that I think about it, its hard to start sometimes. And its been running hotter.
don't know if its me being paranoid, but i'm thinking maybe the HG is going.
I think they're probably un-related. Time to pop the oil cap off tomorrow
Old 03-18-2013, 03:42 PM
catfish21's Avatar
Did you ever find anything my truck is blowing smoke just like you said but even when mine warms up and I give it gas on the declaration it will blow a little white smoke its not a whole lot but I don't like it ay all if anyone thinks this is relates to his problem or is something different let me know
Old 04-08-2013, 11:34 AM
Gizler00's Avatar
I would say VG seals. Mine burns oil on start up and will load up on oil if I let it sit at an idle for more than 10 minutes. Then it looks like im in the mosquito killing business.
Old 04-08-2013, 12:38 PM
catfish21's Avatar
Haha goog thing is though these old motors will just keep on going I've never seen anything like it they just don't stop good luck
cars-guy
08-16-2020 06:59 AM
dumpster84
04-30-2016 06:03 AM
HookahRoo
07-20-2015 07:06 PM
rushw
07-18-2015 01:46 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22r burns oil on startup
