20r Oil pressure drops once warm
I have a 1980 toyota 4x4 with a 20r. It runs great, no noises at all, but once warm, it idles somewhere around 8-10 psi. I'd rather see that number higher than that. Is this something a set of rod bearings could solve? New oil pump? Im not very familiar with the 20r yet, but i'd like to learn as much as possible.
If anyone has any experience with this, or remedies, i'd appreciate it.
check on the back side of the engine, between the block and the head, at the oil bypass thing? dont really know what it is called. but i know on the 22r they clog and cause the oil pressure to drop. eventually will cause top end ploblems if that is the problem.
thats the one. thats all that i know of. just pull that off and clean it out and try and clean as much up in the head and block as you can with a pick or cloths hanger. that seemed to be the only problem with mine. hope that fixes the problem. good luck.
Whomever told you otherwise is kinda clueless, huh ?
Anyway, if you really wanted to raise the pressure, your own description tells you how.
You said when it warms up the pressure drops.
The oil is too thick when it's "cold" and thus the high pressure.
To raise the pressure, change and run gear lube
Anyway, it's not pressure that lubes, it's flow.
Fred
One of those liquid pressure rules.
When velocity increases, pressure decreases.
Pressure goes up, velocity goes down.
And since this is oil we are talking about, like mentioned before, once oil is warmer, its thinner!
If you wanted to install some kind of flow meter for the oil system in the bottom and top end, that could be the best thing to keep track of what your oil is doing and where it is going.
, to think of it the other way.That is as oil cools, it thickens.
BTW, to the original poster, what weight oil are you using ?
Fred
88yodabasket
Jul 13, 2015 01:32 PM
