Sponsored by: CARiD
2010 Taco leafs on an 88?
Old Feb 11, 2011 | 08:44 PM
2DoorRunner's Avatar
My buddy works at a toyota dealership. He scored the suspension from a 2010 tacoma when the owner had a lift installed.
He was curious as to whether or not the taco leaf springs would give his 88 standard cab pickup any lift. Hes looking for 3-4".
I have not personally seen the leafs, so i have no clue as to how they measure up to the stock ones.
I would assume that it would be similar to a 63" chevy spring swap. So yes we are ready to do some fab work Im thinking we will make a temp hanger to see if they will work, and if the axle will be centered in the wheel well. If that works out. We can mess with the shackles and maybe pull or add leafs to get the desired height and flex.
I told him i would ask on here. But i dont think it has been done, because 2010 taco parts are not to common to use for a cheap mod
What do you think?
Old Feb 11, 2011 | 09:21 PM
sandigan's Avatar
Other years of Taco's had inverted leafs. Meaning if you look at them, they almost look kind of worn out or sagging. I wouldn't think these leafs would add 3-4" of lift, but it's worth a shot. FWIW you will most likely have to move mounts around, but it might be worth a shot.
Old Feb 11, 2011 | 09:25 PM
bobby_duce's Avatar
well if he already has it, might aswell give'er hell and try something new! my .02 cents.
Old Feb 11, 2011 | 09:30 PM
Yep, plan on moving the front hanger. And possibly a double shackle if.
Thats what i told him Might just start a new trend! lol
Old Feb 11, 2011 | 09:41 PM
sandigan's Avatar
FWIW, I've had a couple of friends run the double shackles, and they all wen't back to one long shackle. Everything I've read says that the double shackles are unpredictable when sidehilling. I'VE never actually run them, so take it for what it's worth.
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
