Sponsored by: CARiD
2" body lift with 33x12.50s?
Old Jun 25, 2010 | 03:46 AM
Rue86's Avatar
Thumbs down 2" body lift with 33x12.50s?
I've gone digging through the normal IFS lift threads for tires and other searches, but I haven't really found a real answer, so I'm starting a thread just to get a firm answer on this!
I'll be doing a 2" body lift with a drivetrain lift, and I want to run a 33x12.50 under it. The truck currently sits on 34x10.50's with cranked t-bars, but the lets face it, that rides like garbage. Fenders have already been trimmed and such as well.
Will raising the body help for the extra width of the tire under full compression, steering lock to lock, etc? Most likely will put them on a 15x8 Black Rock Lobo's with 4" BS. Unless I need to run a 10" wide rim with them?
Also, what luck have you guys had running lockrights on the trails? Do they hold up well?
Thanks for the help!
Old Jun 25, 2010 | 04:01 AM
rattlewagon's Avatar
yes the tires will fit, but why downsize? id just keep running the 34s. Put the body lift on and relax your tbars (do bj spacers if you need to) and then see what you have for clearance. But you should be fine. 33x12.5 will fit on a stock rig with just a simple pinch pounding, but you said that your fenders are already trimmed, so you should be all set.
Old Jun 25, 2010 | 05:56 AM
MB4runner's Avatar
Or go to 3.75" backspacing, your tires will stick out a bit more but you'll have more clearance.
Old Jun 25, 2010 | 06:43 AM
4Crawler's Avatar
33x12.50s on 8" rims, close to stock backspacing and 1" body lift:
Keeping the tires in as close to the body will help reduce the chances of rubbing while turning:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Jun 25, 2010 | 10:49 AM
Rue86's Avatar
The 34" LTB's that are on it are horrible. I can't stand the road noise on them, and one of them is slightly out of round. A good trail tire, and I'll keep them mounted on a spare set, but I'd also like a wider foot print for the trail, atleast as far as tread is concerned. 34" LTB's really aren't 34" anyways. Factory they only measure like 33.6"? So its pretty much a 33 since mine have some wear on them lol
Old Jun 29, 2010 | 10:48 PM
Nublin's Avatar
Sorry, a little off topic...
Where did you buy the 1"? I was thinking about going 1" instead of 2" on my truck.
Old Jun 30, 2010 | 06:08 AM
4Crawler's Avatar
The kit on the pictured truck is from the web page below:
- http://www.4crawler.com/4x4/ForSale/...t.shtml#GenIII
Old Jun 30, 2010 | 04:50 PM
Nublin's Avatar
Thanks, I see they have a 1.5" kit so I will probably go with that one.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
