1987 Toyota 4Runner 22re green electrical plug under intake
1987 Toyota 4Runner 22re non-turbo. I have an green electrical plug under the intake manifold I do not know where it plugs into. (See first picture) it is part of the wire bundle come from ECU. other electrical green plugs are properly plugged in. (See pictures). Vehicle runs, but has fluctuating idle, will not pass emissions idle carbons, and losses power as motor increases to warm up (I believe this a different issue) does anyone know where this plug goes to or is not used? Than I don’t know what this plugs into Other plugs are correct Correct plug Correct plug
ks
Hi, I'm having all the exact issues with my toyota 4runner 22re. Solution found?
Originally Posted by Az4runner87
I’m pretty sure the idle air control works off vacuum
I have the same model with the same problem and Ive been looking at the same wiring bundle unable to find where two wires and a hose go... Did you ever find some peace in this matter, lol. I can't figure it out and it starting to feel like Ive been at it... way to long for this kind of thing, lol. SOS
