Sponsored by: CARiD
1986 toyota wont start no electricity
Old Feb 7, 2011 | 10:03 AM
heatt69's Avatar
jUST A QUICK UPDATE IT WAS THE MAIN WIRE TO THE FUSE...white wire coming from positive cable on battery to fuse box 80 amp...THANKS FOR EVERYONES HELP!!!!!!!!!!!
Old Aug 4, 2012 | 12:28 AM
tony menzies's Avatar
Question i have no power to a few things can you help
my lights / horn / starter moter wont work there is power to the dash bord in the cab but twhen i turn the key to start the 4runner it wont do anything the glow plugs get hot and i can tow start it ... but when i try to shut the motor off with the key it just keeps running and all so the dash lights stay on when i turn the ignetion off and take the key out .. the wire that gives power to the fuse box gets verry hot as well it came off from the battry and when i reconect it all i get is a few sparks from the termanial and a large knock from a solanoid that is some were on the left rear of the motor ... any help with this little set back will be nice ...
thanks ..
tonymenzies@y7mail.com
Old Aug 4, 2012 | 07:53 AM
RAD4Runner's Avatar
Originally Posted by matstaley
The fuse marked AM1 is actually your fusible link according to the FSM for 1985.
1986 FSM says same.
Heatt69,
That wire runs to a brass plate on the fuse box. Plate connects to 80A fuse which is the grey cube right above the its screw:
Guys with 86Runenrs,
Would you please post pics of wire on your 4Runners? Mine looks like below. I suspect it had been modified because it has a thin (12AWG) blue wire instead of thick white one.
Old Aug 5, 2012 | 05:42 PM
i hav taken the 80amp fuess out but thay look all good exept for the power in wireso i am going to get new ones asap i will let you know if it works .. thanks
Old Aug 6, 2012 | 12:08 AM
  #25
RAD4Runner's Avatar
Check Wiring common to Starting System & Air Shut-Off Solenoid
Originally Posted by tony menzies
my lights / horn / starter moter wont work there is power to the dash bord in the cab but twhen i turn the key to start the 4runner it wont do anything the glow plugs get hot and i can tow start it ... but when i try to shut the motor off with the key it just keeps running and all so the dash lights stay on when i turn the ignetion off and take the key out .. the wire that gives power to the fuse box gets verry hot as well it came off from the battry and when i reconect it all i get is a few sparks from the terminal and a large knock from a solanoid that is some were on the left rear of the motor ... any help with this little set back will be nice ...
thanks ..
tony menzies You must have a diesel (like this?), not common in the U.S. However...
Starter does not work means but tow starts and dash lights on when engine on means battery power is not getting to your starter system, but your alternator supplies power after tow starting.
In order to shut off a diesel engine, one needs to shut off air, not electricity.
That you could not shut off engine probably means your air shut-off solenoid and/or mechanism is not working. Check that solenoid making a sound. If it does work, it should actuate something that shuts off air. If you're getting sparks when solenoid energizes, it could be that solenoid's drawing to much current (something else is wrong with it- coil shorting to ground maybe? plunger stucc?)
Suggest you check wiring that is common to starting system and air shut-off solenoid.
Old Sep 22, 2013 | 09:02 AM
  #26
Turbo A.K.A Patches's Avatar
Would like to know what the am1 fusible link is for so I can find my short!
Old Sep 26, 2013 | 06:51 AM
  #27
aasalaiz961's Avatar
1987 toyota truck 22r need help with fuse panels
Hi yall,
My name is Avondale but you can call me Von... I just bought a 1987 toyota but I do not know what fuses go where and I am getting tired of trying to find information on the internet. Surprisingly GOOGLE doesn't know it all... If anyone can help me out I would appreciate it. I just do not know what size to put where... I have a panel at the drivers kick plate and one under the hood, if there are any others please let me know. This is my first time ever asking a forum for help... Thanks guys!!!
Von
Old Oct 20, 2013 | 01:00 PM
  #28
heatt69's Avatar
Originally Posted by heatt69
I have a new battery just replaced it because I let my 4runner 22re sit for a few months..it was under warranty so I said why not get a new one...Now Its completely dead nothing, no light no clicks no anything...All fuses look good cables looks ok...Any ideas what else could cause O power as if u had no battery in? My fog lights work that r hooked straight to battery but thats it....
Does anyone one know the easiest way
To get your oil pan, to fix a leak
Old Oct 20, 2013 | 01:01 PM
  #29
heatt69's Avatar
Does anyone know the easiest way to get to the oil pan to fix a leak. .1986 runner
Old Oct 20, 2013 | 01:20 PM
  #30
rokblok's Avatar
Search Oil Pan removal in the search window. Or something similar. Or, if necessary, start your own thread.
I would help, but I don't know what we are working on...
Old Oct 20, 2013 | 01:42 PM
  #31
heatt69's Avatar
1986 4runner 22re
Old Feb 7, 2014 | 01:14 AM
  #32
JD82Yota86's Avatar
The 80 amp fl blew on my 86 sr5 fwd. i cant find another anywhere! Any suggestions. ( I had to jump that circuit just to drive her. But it being just rigged up is driving me crazy)
Old Feb 7, 2014 | 01:21 AM
  #33
JD82Yota86's Avatar
1986 FSM says same.
Heatt69,
Im trying to find a new fusible link exactly like what you are holdin! Where can i find one?
Old Nov 12, 2015 | 06:30 AM
  #34
Dmills's Avatar
I have a problem also. My 86 truck will turn over but not start no inside lights will come on. Headlights work battery is good. I noticed the 80 amp fuse was broke so I tired to pull it out and it broke. I bridge it and the lights on the inside will come on but still want start can anyone help I have to work tomorrow and need this fixed. I really messed the 80 amp fuse up trying to get the broken fuse out.
DacodaYota
Sep 2, 2015 02:13 PM
noahstancik
Jul 10, 2015 11:18 AM
bigblue82
10
Jul 6, 2015 08:27 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
Taz22R
Jun 21, 2015 04:44 PM
