Sponsored by: CARiD
1985 Toyota pickup
Old Jan 8, 2010 | 06:33 PM
rednecktruck22's Avatar
Originally Posted by yoder519
ok....go to marlincrawler.com, trail-gear.com, yadadayayayayaddd. click on differentials, then go to lockers. you have open diffs. when you lock in teh hubs, all your doing is puttin in in 4wd. in teh rear, the tire with the least amount of traction will spin. you cna go on google and type in toyota lockers. you have an 8inch front and rearend
How do i know that i have 8inch front and rearend? I dont what where one tire spins i want them both to spin so i don't get stuck as easy.
Old Jan 8, 2010 | 06:35 PM
toyota4x4907's Avatar
Because Toyota p/us and 4runners with factory solid axles have 8" front and rear diffs.
If you dont want the tire spin, then get a locker, like has been mentioned many times already in this thread.
Old Jan 8, 2010 | 06:36 PM
4Crawler's Avatar
You can loop the axle code on teh VIN plate:
- http://www.4crawler.com/4x4/ToyVIN.shtml
But unless someone has swapped in another axle, you have 8" front and rear. An auto-locker or manually selectable one (e-locker or air locker) will do what you want:
- http://www.markerink.org/WJM/HTML/diffs.htm
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#DiffInfo
Old Jan 8, 2010 | 06:41 PM
ok does the local auto parts place sell lockers for the truck??
Old Jan 8, 2010 | 07:19 PM
  #25
TORTIS's Avatar
I hope you didn't post this over on Pirate 4x4 forum. Crash would love you!!!!!!!!!!!!
Old Jan 9, 2010 | 06:18 AM
  #26
Nope I didn't this is the only post i have done about this.
Old Jan 9, 2010 | 05:45 PM
  #27
TORTIS's Avatar
You chose wisely.
Old Jan 9, 2010 | 05:56 PM
  #28
MuddfreaksOffroad's Avatar
dude you need to go read up alot before you go wheeling again. If you dont even know the difference between a locker and locking hubs then you also need to LOOK OVER and LEARN your truck. Sorry if im harsh but thats just not smart wheeling when you dont even know anything bout your truck! ... again sorry for being harsh
Old Jan 9, 2010 | 07:40 PM
  #29
it's N/P i know what locking hubs are because i have them in the front but i didn't know that i had limited slip in the rear, untill i got stuck for the first time. But i was just woundering where to get the locker from i didn't know what is best to do get a locker or weld the spider gears. and also i am learning as i go too so it's cool that is why i like places like this that i can talk to other people and get there info and help from about ideas.
Old Jan 9, 2010 | 07:45 PM
  #30
peow130's Avatar
If you want a cheap spool, pull out the differential and just weld up the spider gears..
Old Jan 9, 2010 | 11:13 PM
  #31
honeslty that is a cheap way to do it, but personally if you wanna wheel and dont wanna spend lots of money in the long run get a locker. Nothings cheap cheap in this world and you wanna get good quaility equipment id suggest a detroit or aussie or if you want selectable get a arb and im not sure what others are selectable youd have to shop around. either way welding it willlll work but youll go threw tires.
Old Jan 10, 2010 | 08:00 AM
  #32
well it just going to be in the mud that is it. It is not street legale and will not be i got the cat cut off, and it is not tag or inspected and not really plan on it so yeah
Old Jan 10, 2010 | 08:17 AM
  #33
If i weld up the spider gears now. Then later go out and buy a locker/spool for the truck. what then would i have to buy to do that.
here is a question i not sure of.
Does the spool just replace the spider gears?
Old Jan 10, 2010 | 09:40 AM
  #34
yoder519's Avatar
i already told you where to go to find lockers. marlincrawler.com, trail-gear. com.
Old Jan 10, 2010 | 10:15 AM
  #35
i am not asking where
  #36
Old Jan 10, 2010 | 10:16 AM
  #37
yoder519's Avatar
i msut have read this wrong. i though tyou was askin where to get them
Old Jan 10, 2010 | 10:19 AM
  #38
yoder519's Avatar
man we are trying to be rude. bu tyou need to search young grasshopper. ALL of teh questions you have asked could have been answered with a simple search on here, googel, and other places. Search-we all do it. go to googel, type in "locker in toyota" or "how does differential locker work"
Old Jan 10, 2010 | 10:23 AM
  #39
camo31_10.50's Avatar
dude..just take it to a shop..and tell em you want to weld up the diff's front and rear...it'll be ok since it's strictly a trail-rig...
Old Jan 10, 2010 | 10:26 AM
  #40
dont have money to take it to a shop ples i can do the welding myself
