Sponsored by: CARiD
1985 4runner questions?
Old Sep 9, 2010 | 03:57 AM
2003mikem's Avatar
I just pick up a 1985 4runner 22REC, I need to put a different engine in it.
What years will fit?
Also are the 22r 22re 22rec the same block and head ??
I will be using it as a daily drive and a personal plow truck. once and a while hit the baby trails.
The head was rebuilt? Or so I was told. I think it was a hack job.
At start up the oil light comes on. Which in my mind says the main or rod bearing are going out?
188000 miles on the unit?
Am I better off putting new rod and main bearing in? or a used engine ?
Any shop up by me in Wisconsin wants way too much to rebuild a short block
Old Sep 9, 2010 | 04:08 AM
xxxtreme22r's Avatar
you sure the oil light sender is still good? get an aftermarket gauge for the oil pressure. I would hate to see you ditch a perfectly good motor because of a less than $20 sender.
Old Sep 9, 2010 | 04:09 AM
2003mikem's Avatar
I am hearing a slight knock.
Old Sep 9, 2010 | 05:13 AM
greatskiiiier's Avatar
drive it till it blows up
Old Sep 9, 2010 | 05:15 AM
2003mikem's Avatar
I would love to, but I need it to be able to plow me out and get to a-b, and I don’t want to swap it out in winter. My garage is a joke. The 4runner barely fits.
Old Sep 9, 2010 | 09:26 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
79-84 And 85-95 will not interchange.
The block deck was de-decked in 85. So you cannot and should not interchange the heads.
85-95... Blocks are all the same (Ex Turbo) Semi-flat topped pistons. Have a slight dish.
79-84 blocks are easily ID'd by the high top pistons.
Here's a RE cover on an early 22R block
Old Sep 10, 2010 | 07:02 AM
2003mikem's Avatar
I pulled each plug wire and found the knock gets quieter when I take # # wire off.
Old Sep 11, 2010 | 05:37 PM
whokrz's Avatar
There are many things that can make a 22re sound like it is knocking.
As xxxtreme22r recommended get an aftermarket gauge for the oil pressure.
Doing a compression check also wouldn't hurt.
If the oil and compression is good then use the factory service manual to start testing the efi. There is a link to FSMs in my signature.
Old Sep 13, 2010 | 03:00 AM
2003mikem's Avatar
Check the compression, had about 100-105 in each cylinder, pulled the engine Saturday morning, cyl # 4 rod bearing was shot.
I picked up a rebuilt engine and trans from a 1987 SR5 4X4 Truck, Toyota rebuilt the engine in 2001 and the trans in 2003. All stock yota parts were used.
The 87 was a carb model
Old Sep 13, 2010 | 03:04 AM
2003mikem's Avatar
i paid $375.oo for the engine trans and t case
Old Sep 16, 2010 | 06:37 AM
2003mikem's Avatar
3rd member and gears question and suggestions
I have a 1985 4Runner.
Solid axle
22REC
I bought it with 31” new off brand mud tires.
I would like to change the gears.
From what I have read, I should go to a 4.88 ratio? Is this correct?
If so is there any truck or 4runner I can get a full 3rd member out of and use ?
The 4runner will be used as a daily driver and as my personal plow truck…
Thanks for any help
Mike
Old Sep 16, 2010 | 11:10 AM
94'wheeler's Avatar
From what I've read on here, that seems to be the way to go. 5.29's for 35" and up, 4.88's covers you below 35". hope that helps!
https://www.yotatech.com/forums/f120...y-axle-219626/
Peep the link, few posts down might be what your looking for!
Old Sep 16, 2010 | 11:19 AM
2003mikem's Avatar
i have 31" right now. the biggest i would run would be 33"
Old Sep 16, 2010 | 01:36 PM
1styota4X4's Avatar
4.88 for 33will keep your speedo almost dead on.
Old Sep 17, 2010 | 06:01 PM
whokrz's Avatar
For my DD I run 5.29 and 32s. The extra torque is nice but the rpms get up around 3500 at 70mph and 3200 at 65pmh
Old Sep 20, 2010 | 08:46 AM
2003mikem's Avatar
well what daya think ?
Old Sep 21, 2010 | 06:49 PM
whokrz's Avatar
Looks pretty clean for a 25yr old rig.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Cplmike
Jul 8, 2015 08:47 PM
bryan34w
Jul 6, 2015 05:53 PM
