Sponsored by: CARiD
1980 Wheel Bearing Advice
Old Dec 6, 2009 | 08:21 AM
jpeters's Avatar
I'll start off with just a little about my truck since I'm new to this site. 1980 Toyota 4x4 pickup. Locker in the rear. 33 inch mud terrains. 20r with newer carb, air intake, header, and 40 series flowmasters. rock slide bars all around. pretty basic.
Problem: I was checking out the bottom of my rig yesterday and noticed the inside of my tire was streaked with grease from what apparently was the axles. I have looked around on the forums but noticed they all seem to be newer rigs for this repair. Can anyone give me any and all the advice you can give! Please help. I have lost a lot of grease.
Old Dec 6, 2009 | 09:16 AM
Ed H.'s Avatar
http://www.4crawler.com/4x4/CheapTri...eWasherRemoval
http://www.4x4wire.com/toyota/mainte...ont_end/rotor/
http://pirate4x4.com/forum/showthrea...nuckle+preload
http://www.lukemiller.org/toys/1985_...t_axle_FSM.pdf
marlin crawler, trail-gear, all-pro all have rebuild kits, I used the marlin kit on mine a couple weeks ago it comes with HD axle seals which i liked, if you get anyone elses kit just order marlin seals i think they are 10 bucks and well worth it.
Old Dec 6, 2009 | 09:50 AM
Plumbrbob's Avatar
a front tire soaked in gear oil is a sign that your inner axle seal is bad. this seal also leaks if the housing gets bent ...doing any jumping lately? if not its time for a rebuild
Old Dec 6, 2009 | 06:55 PM
jpeters's Avatar
naaa i haven't been doing any jumping. I try to baby it, at least to a point. What I was really looking for is an online tutorial for doing this. My haynes manual isnt exactly matching up to what i have.
Old Dec 6, 2009 | 07:11 PM
jpeters's Avatar
Just saw the links from the first post. thanks
Old Dec 7, 2009 | 06:06 PM
jpeters's Avatar
I still have a problem. I cant get access to the nuts holding the hub body. On the links given by ed h the pictures are the same as in my haynes manual. I can see them but there is a sleave that extends past the bolts. And the sleave is too close to get any socket down in there. Does anyone know what im talking about?
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
DrZero
18
Jul 24, 2015 11:31 PM
msane99
Jul 17, 2015 10:13 AM
Gamble_STi
Jul 7, 2015 07:54 PM
