Items Wanted Vehicle and non vehicle related
Radiator needed for 22RTE
Old Feb 13, 2012 | 03:37 AM
toda90's Avatar
Hey I'm trying to find a radiator for an 86 22rte. I can't find one with the return line port on top of the radiator. I would rather not splice into a line and just stick with the right radiator. Anyone know where I can find one I've looked everywhere I know to look both online and shops. Let me know if you know where I can get one
Old Feb 13, 2012 | 03:38 AM
toda90's Avatar
Return line for the turbo
Old Feb 13, 2012 | 10:12 AM
mosk's Avatar
Hard to find one, and even harder to find one in good shape. You can get one custom made, or modify a 3 row 22RE radiator, but a cheaper and equally good option is to get a 3 row 22RE radiator and splice one of these into the top hose:
$23 + shipping from LCE:
http://www.lceperformance.com/Water-...-p/1033001.htm
Add a right angle fitting and a length of hose and you're set.
-Jeff
Old Feb 13, 2012 | 07:29 PM
toda90's Avatar
Alright I'll just go that route.
Old Feb 14, 2012 | 08:45 PM
toda90's Avatar
is the fitting a fairly easy one to find? like a common one you would find at a hard wear store
Old Feb 14, 2012 | 09:26 PM
mosk's Avatar
Yes, you can get these fittings at Home Depot or AutoZone/PepBoys/etc.
You need one 3/8" NPT male hose barb:
Make sure the diameter of the barb matches the inside diameter of the hose you intend to use -- it's either 1/4" or 3/8", I forget which. Oh, and you'll need a hose clamp and some teflon pipe tape for assembly. When it's done it will look like this, more or less:
Clear?
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
