4.56 e-locker third. Or possibly an 8" third
Hey I'm looking for an 8" third as close as I can get to a trd e-locker 4.56. I would also go for an open 4.56 8" but I might need another 90-95 4runner housing as I modified mine to fit the e-locker that I just blew up. I might also consider 4.88's or a cheap 4.10 or 4.30 to get my truck rolling again for now. Once I get a rear I will need a matching front too but I'm waiting till I get the rear as I might end up with a different ratio. And no my e-locker is not available to sell as I still might just re-gear it.
Click on the thumbnails if you want to see the larger pictures.
I was messing around on the street haha. Guess it couldn't handle about 7000 pounds with the trailer truck and tools in low range 2wd dumping the clutch. Haha. 1st and second gears spun the tires before it hooked up but 3rd gear grabbed hard enough that my coworker said my front wheels came off the ground then bang grind clank. Well I found the limit of the stock 4.10's messing around way harder on the truck than I should have been. This was a stock from the factory 4.10 e-locker rear with 140,000 miles on it that I had in my 3.4 swapped 1991 4runner.
myotherrideisayoshi
Sep 29, 2015 05:41 AM
charlie_fong
Sep 27, 2015 10:06 PM
