What does a flashing A/C dial light mean?
Old Mar 8, 2006 | 04:56 AM
SoL's Avatar
SoL
Hey guys/gals, the A/C light for my 2003 4Runner started flashing a couple of days ago. It seems to be causing the heating and air to go kinda crazy. Any ideas on what this means? I thought maybe it means it needs a recharge but that is just a guess. If anyone knows the page in the manual that references such an issue, I'd appreciate it also.
Thanks in advance.
Old Mar 8, 2006 | 08:14 AM
SoL's Avatar
SoL
Never mind, found another thread with the same problem!
Old Mar 8, 2006 | 10:52 AM
MrTom's Avatar
TSB: EL011-05 A/C LIGHT FLASHING - MAGNETIC CLUTCH RELAY
6/3/2005 - 2001 – 2004 Toyota Camry, ECHO, & Celica. 2002 – 2004 4Runner, Corolla, & MR2 Spyder. 2003 – 2004 Highlander, Matrix, Sienna, & Solara. This bulletin is to provide information regarding countermeasures to the A/C magnetic clutch relay for A/C light flashing (inoperative A/C) issues on some vehicles equipped with a magnetic clutch compressor.
Old Apr 21, 2006 | 08:32 AM
SoL's Avatar
SoL
The dealership says since my 4Runner is NOT under warranty anymore, then it costs about $130 to fix. Anyone know how difficult it would be to fix this? Or what is the cost of a replacement part? I'm not usually a stickler for paying to get things fixed but my daughter's birthday is coming up and I'd rather spend the money on her...
Old Apr 21, 2006 | 09:12 AM
Good Times's Avatar
I thought TSB's were a fix that the dealer had to do regardless of the vehicle in warranty or not. Maybe I'm wrong but I'd check out another dealership and verify the findings.
Good luck
Old Apr 21, 2006 | 11:08 AM
SoL's Avatar
SoL
According to the person I spoke to, only recalls were required to be fixed. I plan to ask around however as I had thought the same as well. Anyone else know for sure?
Old Apr 21, 2006 | 11:10 AM
Localmotion's Avatar
that sounds familiar TSB's arent required to be fixed unless under warranty.
If it just blinks..id leave it alone
Old Apr 21, 2006 | 03:57 PM
SoL's Avatar
SoL
Well, unfortunately, when it blinks, the A/C isn't cold...it just blows air (warm usually). Right now, it is working fine but I live in GA and as summer approaches, I'm not too keen on not having A/C...
Old Apr 21, 2006 | 04:20 PM
Sharp4runr's Avatar
Can you get a copy of the actual TSB? It may have it's own warranty date. For example, the Sulfur TSB (http://www.toyota-4runner.org/attach...=&postid=30258)
As you can see it says it is applicable for 96 months or 80K miles. It makes no mention of the 3yr/36k warranty so I would think that this TSB would still require repair even though the vehicle is over it's standard warranty since it encompasses the standard warranty.
Like Lance said, check around other dealerships and see what they can do for you. Or get a copy of the actual TSB and see what the warranty terms state. Also the relay isn't too expensive. See this thread as someone said they bought it for $71. Also this thread has the PN for the relay: http://toyota-4runner.org/showthread...blinking+a%2Fc
mussy01
Dec 13, 2016 08:20 PM
Shoua
13
May 22, 2016 05:19 AM
AkitaDog
Sep 1, 2015 08:05 AM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
