A/T service interval
I have 52K on my '05 Taco. I just took it in today to have the transmission serviced, and 20 mins. after I dropped it off he comes back and says, " We just ran the numbers on your truck and you've got TYPE-W fluid and it's good for 100K." Can this be true? Can different fluids make that much difference and if so, why don't they all run TYPE-W?
Tell him "I dont care what is has, change the fluid"
I would not trust ANY Auto trans fluid to 100K, i dont care what they say. Toyota also said you didn't have to change the oil in your Camry, Solara, Avalon, etc for 10K miles. And now they are dealing with a GIANT sludge issue and paying out the behind for it.
Change the fluid.
Change the fluid.
yah I dont trust that either. The "w" or world standard fluid is claimed to never needing to be changed. BS. I say do it every 60K. Its kind of a bitch to change as you dont have a normal dipstick and the fill hole is in a weird spot.
And it's not Toyota that made the fluid or decided that the fluid will last longer. The Society of Automotive Engineers (SAE) is who decides which types of fluids will last longer, and then Toyota makes the decision as to which fluid to use and exactly how many miles it should be left in.
It wasn't Toyota's marketing department that says it can be left in for 100,000 miles. It's the engineers. Toyota engineers can make mistakes, but this may not be one of them. After all, other engineers from other manufacturers are saying the same thing about transmission fluid intervals.
Toyota wouldn't say that the fluid could last for 100,000 miles if it couldn't. Why? Because they wouldn't intentionally do anything that would cause more warranty work, recalls, or TSBs.
Transmissions don't pollute their lubricants like engines do. So unless the transmission has overheated enough to damage the fluid, it can very well last for 100,000 miles.
And modern lubricants have additive packages and such that not only make them lubricate better, but that also makes them last longer.
As far as engine oils go, the manual for my Honda motorcycle says that the oil change interval is 8,000 miles. I've been changing it at that interval ever since I've had it with no problems at all, using either Honda's oil, Amsoil, or Mobil1. Motorcycles are harder than cars on oil, because most of them (and mine) also use the engine oil to lubricate the transmission and the multiplate wet clutch. Plus I've been very hard on the bike and didn't break it in right. I found out it's top speed (150) the third day I owned it, and it was nowhere near broken in.
The problem with the engines sludging may not have been just due to the oil change interval. It could have also been due to the engine oil not getting hot enough to burn away the moisture and other contaminates that form in the oil over time (which causes sludge). Reducing the oil change interval would certainly have helped, but the interval probably wasn't the only factor.
Now I'm not saying that it would hurt to change the fluid sooner. I would make that determination based on what kind of loads and abuse and ambient temperatures the transmission sees, not based on lack of knowledge and/or misinformation about how good some modern lubricants are and why the manufacturer says the lubricant can be left in longer.
With mine, I tow my boat (4500-5000 pounds) on a regular basis about 45 miles one way to Tampa Bay, and I tow my trailer with my motorcycle and ATVs 850 miles one way to Kentucky at least once a year (will be doing that this summer). Plus, mine has to deal with Florida heat. So I'll probably change mine sooner than 100,000 miles, since mine sees harsher use than average.
Our definition of the life of a vehicle and toyota's definition are totally different. For me lifetime of a vehicle refers from birth, to when the vehicle enters the junk yard. for toyota the lifetime of their vehicle is when the vehicle is no longer their responsibility (warranty is over).
"Lifetime" automatic transmission fluid (ATF). In a legal context, "Lifetime" really means the duration of "toyota Powertrain Warranty". Upon its expiration, the $JOKE$ is on you.
It wasn't Toyota's marketing department that says it can be left in for 100,000 miles. It's the engineers. Toyota engineers can make mistakes, but this may not be one of them. After all, other engineers from other manufacturers are saying the same thing about transmission fluid intervals..
that why i said early and often!
My reason is more than just "I don't believe the fluid will last that long" like it is with some people here. My reason has to do with hard use and hot ambient temperatures.
If I never towed or drove off road, then I would go the full interval. So then I don't fully agree that it should be less than 100,000 miles. Like I said, it depends on the circumstances.
I've had a Mazda M5OD manual 5 speed transmission that used Mercon automatic transmission go bad because I didn't change it often enough. But then again, I also towed alot with that vehicle ('94 Mazda Navajo, same as a same year 2 door Explorer), did alot of slow speed off roading and rockcrawling (which allows heat to build up), and took a few trips out west, in the desert in the summer where temps were well over 100 degrees.
The factory 30,000 mile interval would have been enough if I had not towed or driven off road. But for me, I should have done it every 15,000 miles.
AFAIK, Type WS fluid is recommended at 96000km on Lexus vehicles. That's around 60k miles.
At 52k miles, it won't hurt a thing to change the lfluid. Type WS is more expensive, and somewhat labour intensive to change the fluid. The trick is to properly check the fluid level, which has to be done at a specific ATF temperature.
No, it's not something that you'd want done at 4:45 on a friday afternoon. Make an appointment for a weekday morning
Dale Johnston
11
Oct 31, 2015 10:22 PM
Boomer8404
Sep 24, 2015 01:12 PM
Boomer8404
Sep 20, 2015 06:15 PM
