quick Seafoam & O2 Sensor question
Old Mar 2, 2010 | 01:46 AM
joshik's Avatar
gonna seafoam my 03 4r this week. i know there is a plethora of info on here....maybe too much to filter through and even search though
quick question tho, i know sometimes the O2 sensor can get gummed up when seafoaming so people remove the O2 sensor when seafoaming. it is my understanding there are two O2 sensors. do both get gummed up or just sensor 1?
also, any ideas of what to plug up the hole with temporarily when seafoaming with the O2 sensor is removed?
thx!
Old Mar 2, 2010 | 02:20 AM
AlexJet's Avatar
After rustproofing my truck it stared to through P0420 code when moisture. I'd just rap them down with something and/or spray wuth WD40 prior spraying.
The top ones are Air/Fuel mixture sendors while the bottom ones are Oxygen sensors. You can potentially damage both.
Old Mar 2, 2010 | 10:03 AM
joshik's Avatar
so gonna do seafoam but i cant seem to id the proper hose, or brake booster hose....i cant seem to find what looks to be a normal brake booster. any help please.
thx
Old Mar 2, 2010 | 10:30 AM
Fink's Avatar
Have you tried searching on here at all? Google? YouTube?
It's all over the place man.
I would use YouTube as you can actually watch people do it and if I remember correctly, they have a newer Tacoma or 4Runner on there.
Fink
Old Mar 2, 2010 | 10:32 AM
Fink's Avatar
Here's a quick link I got by searching for "Seafoam Toyota" on YouTube.
I didn't have a chance to look through all the vids but maybe one of those will have your answer.
Like I said though, there are tons of threads on here about it.
Fink
Old Mar 2, 2010 | 11:19 AM
joshik's Avatar
yeh, i searched before i posted. hard to sift thru hundreds of posts, even with search. searched google as well. youtube has mostly people showing off how much smoke they blow out after SFing so no use. i will keep looking.
Old Mar 2, 2010 | 12:28 PM
joshik's Avatar
didnt find anything, but poked around the engine.
turned on the motor and disconnected this hose.... major suction. so i can use this right?
Old Jul 14, 2010 | 09:17 PM
phildelfino's Avatar
https://www.yotatech.com/forums/f116...-truth-160614/
wanna read about it. ^^^
Old Jul 14, 2010 | 09:36 PM
85gijunk4x4's Avatar
when i did mine i put seafoam trough my brake booster hose, if you look at the master cylinder, there is a hose behind it kinda close to the firewall, pull off the nearest hose to the mc with the engine running and you can tell if its a vac. hose. i put a funnel in the hose a poured the seafoam down the hose slowly. i didnt bother with the 02's, but im sure remoing them and plugging the hole is better then leaving them in.
kawazx636
Oct 6, 2021 03:03 PM
zytra
Jan 24, 2019 03:16 PM
charlie_fong
Sep 27, 2015 10:06 PM
sanctfy
Sep 13, 2015 06:33 PM
DiggnDeep
Sep 3, 2015 02:45 PM
