Off Road MODS wish list priority
I bought my 4runner (silver '05 SR5 4wd) back in july and have since taken it off road a few times. I'd like to turn this into a somewhat serious trail rig during the next year or two. Haven't really done anything yet but i wanted some input. I'll be going active duty (USMC) in 2 months so i'm not planning on commuting much in the next 10-20 years (hopefully) so a hit in a few mpg isn't going to kill me, however i would like some input on what these mods will do to handling/performance/economy. Right now, i'd like to put a shrockworks bumper (or maybe ARB depending on the wait), winch, OME kit, Sliders, beefed up skid plates, and maybe a rear locker (ARB) if i get stationed somewhere where i'll need it. What would be the best MODS to do first (i'm thinking ordering the bumper, then getting the suspension when the bumper arrives since you need a beefed up suspension for the bumper) and then adding on from there.
To some extent, its a matter of opinion about the best order for mods. I think its important to know where you want to go with it so you don't waste money changing the same thing twice.
I agree that a good set of tires should be the first priority - the original equipment tires are street tires, provide poor traction and won't take much abuse.
I would hold off on lockers until the end. The ATRAC on these truck works fairly well and is definitely better than your typical 4x4 with open differentials. Besides, considering the poor ground clearance these trucks have in stock form, having a locker without a lift and sliders will just get you into trouble.
My second priority would be either armor or a lift. You can make arguments for both. Sliders and skids are a definite must if you want to wheel hard and if you don't have a lift, you will definitely make use of them on moderate trails because of the poor ground clearance. If you lift before sliders and skids, you should be able to run moderate trails without too much worry. If you invest in some adjustable coilovers, you could lift early on and adjust them later to compensate for added weight from armor, bumpers and winch.
By the way - I have OME lift, Shrockworks sliders and 265 70 r17 BFG all-terrains on my 4-Runner. I did the lift and tires soon after I bought it and added the sliders a few months later. I am very satisfied with this set-up.
Considering the ground clearance on these trucks isn't great, I'd do armour first. Oil sump, tranny, T-case, and gas tank, then rear bumper, sliders lastly front bumper.
Then choose a tire size and lift to match, no more. Then get lockers and gears all at once.
My stock 06 4RUNNER V6 has nearly complete skids minus rear diff. I just installed OME 885 front and 895 rear with stock x-reas shocks. I love the ride. Very smooth. Next I will be getting tires (285x70 17). Just throwing the info out there. Oh my runner sits only 3/4 of an inch high in the rear. Perfect!
As for the OP question (not to totally hijack the thread) I am going with armour before tires/lift mainly because it is more affordable.
it depends on what you want out of your truck. if you want performance, go like this
locker
lift
tires
trail armour
if you want the feel and look of a modded lifted truck go
lift
tires
armour
locker
or switch lift/tires with armour.
locker
lift
tires
trail armour
lift
tires
armour
locker
kept the x-reas shocks. Ride is smoother due to better quality more progressive rate OME springs. X-reas does work with the lift I will loose a little articulation at full extension due to stock shorter length shock. I am very happy with this set up so far. Virtually no body roll and smooth valving in the x-reas Yamaha shocks. If you get your rig up off the ground you are far less likely to make contact unless you are rock crawling. I installed all 4 springs myself. It was easy and the lift (3RUN-FRC-885) is $359.99 from TOYTEC.
It sounds like your set up is pretty good either way. You got the lift for a good price, and the stiffer springs for added armour. I am guessing this is better than just a spacer lift.
Yes with x-reas you can install just the front and rear springs. If you would like I can send some pics of my truck: me e-mail address is saintbeau@gmail.com
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
priest16
15
Aug 6, 2015 07:43 AM
toyoda8488
Jul 5, 2015 10:18 PM
