Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS
Help! I bought a Revtek 3" suspension lift (part #431) and had it installed professionaly at a shop but now have problems. My 4runner is a 2004 SR5, 2WD. Immediately after the lift was installed, the VSC, VSC OFF, and ABS lights lit up on the dash (no check engine light). They plugged in thier computer reader thing and it said there is a sensor error at the right front tire and a ABS malfunction. The shop checked the sensors but they swear everything is working properly. Anyone else have a similar issue or anyone know what to do.
Already tried disconnecting battery, reseting error, pulling FCU (or whatever it is) fuse.
Please help!
Please help!
They may not have been careful with the ABS sensor wire when installing your spacers. In this case they probably damaged the wiring. You must be very careful about the ABS wire not to stretch it. I'd almost guarentee you this is what is happening.
This post does a great job explaining how to check.
http://www.toyota-4runner.org/4th-ge...tml#post771215
live4soccer7
May 11, 2016 06:52 PM
