YotaTech Forums
-   03+ 4Runner/GX470, & 05+ Tacomas (https://www.yotatech.com/forums/f117/)
-   -   Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS (https://www.yotatech.com/forums/f117/help-problem-w-revtek-lift-abs-vsc-vsc-off-lights-116452/)
clarky_007 05-23-2007 04:36 PM
Help! I bought a Revtek 3" suspension lift (part #431) and had it installed professionaly at a shop but now have problems. My 4runner is a 2004 SR5, 2WD. Immediately after the lift was installed, the VSC, VSC OFF, and ABS lights lit up on the dash (no check engine light). They plugged in thier computer reader thing and it said there is a sensor error at the right front tire and a ABS malfunction. The shop checked the sensors but they swear everything is working properly. Anyone else have a similar issue or anyone know what to do.
Already tried disconnecting battery, reseting error, pulling FCU (or whatever it is) fuse.
Please help!
Expat 05-23-2007 09:32 PM
They may not have been careful with the ABS sensor wire when installing your spacers. In this case they probably damaged the wiring. You must be very careful about the ABS wire not to stretch it. I'd almost guarentee you this is what is happening.
LEADfoot 05-24-2007 05:52 AM
i agree
i came with'n seconds of doing that very thing
when i was trying to get clearance for my OME lift
it's way tight in there and hard to notice every detail
mac4runner 05-24-2007 09:26 AM
I agree with the previous two posts. Been there, done that. Replace the ABS sensor wire and your problem will be solved. :guitar:
clarky_007 05-24-2007 10:57 AM
Thanks for the responses. The sensor is already on order so hopefully that will fix the problem.
coconut 08-19-2008 12:24 PM
any one know how much the abs sensor wire cost????
coconut 08-19-2008 12:25 PM
cost of abs sensor wire??
mac4runner 08-20-2008 11:07 AM
If memory serves, it's about $60.
ksu1998 08-20-2008 08:39 PM
You lower a Lexus or lift a 4runner...same result. Watch those ABS sensor cables...
92yota808 07-17-2012 11:36 PM
i know its an old post rather making a new post, how do you know if the wire is bad?
ARK_SWAMP_RIDER 07-19-2012 05:44 PM
This post does a great job explaining how to check.
http://www.toyota-4runner.org/4th-ge...tml#post771215
DIHOWARD 08-18-2012 05:19 AM
I had a wheel bearing go out and had the same problem, Toyota wants $225 for the sensor, I found one on ebay for $19.99
