Electrical Meltdown
Old Oct 8, 2013 | 07:37 AM
nfrantz007's Avatar
Electrical Meltdown
So my 03 Sport recently decided to have a major electrical melt down.
These items do not work:
1. Power windows (all)
2. Rear Gate (no power at all)
3. Parking Lights (all)
4. Dash lights (illumination)
5. Constant 12 v power to parking light on trailer pig tail
What I have tried for each:
1. Fuses - (all, multiple times, visual and ohm/power check); window lock out switch , swapped relays
2. Fuses (all), getting power to ECU, swapped relays, unplugged battery and ECU for 10 min.
3. checked bulbs and fuses
4. checked fuses
5. Traced power (black/green wire) from pig tail all the way to source, constant 12 v throughout...
I know the rear gate ecu and lock mechanism can go on these vehicles. However, with the other issue described above I'm not convinced this is the problem. I found out about the trailer parking light issue when I hooked my trailer up and melted the wire on the trailer.
I'm at a loss on where to go from here... Thoughts?
Old Oct 11, 2013 | 06:43 AM
Browntown3's Avatar
Have you checked your alternator ?
Old Oct 11, 2013 | 12:25 PM
vital22re's Avatar
totally a bro
the master switch on driver door if bad will affect all windows.
the headlight switch would kill the parking lights and trailer lights. however a faulty trailer wire harness would affect that as well
Old Oct 11, 2013 | 01:02 PM
Papadeath's Avatar
You sure you have traced back all the wiring? Sounds like you may have cooked one (or more) during a dead short. seems like you would have discovered it with the fuses, though. Time and effort my friend. Good luck.
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 24, 2015 01:12 PM
xzen73x
Sep 14, 2015 03:00 AM
