Custom 3/4" thick 4th gen top spacer order
#101
Originally Posted by fourunnabilly
i had no more rubbing issues than with the 33's, just on the a-arms. my current 36's on the 22's do stick out a bit farther, about 1.5-2" beyond the fender, but after some more trimming and grinding are still clearing fine.
Billy
Billy
#103
Originally Posted by ahriman
billy- do you have any close-up pics of your trimming?
Billy
#104
here are some pics of the spacers before and after :
measured as follows:
before:
driver's side front: 35 7/8"
passenger's side front: 36"
driver's side rear: 37 7/8"
passenger's side rear: 38"
after:
driver's side front: 37.5"
passenger's side front: 37.5"
driver's side rear: 38 1/8"
passenger's side rear: 38 1/8"
net gain:
~ 1.5"
before:
after:
net gain:
~ 1.5"
#106
before:
after:
net gain:
~ 1.5"
before:
after:
net gain:
~ 1.5"
I'd be intereseted in knowing how well it aligns.
#108
any pics billy?
Billy
Also, to those of you that installed our front spacer this weekend, expect everything to settle and give you a net gain between 7/8"-1". It took mine a couple days, and is resting at 1" even as we speak. Also, as long as you have the nuts on tight on the three studs, you will be fine. We settled upon 3/4" as that was what appeared to be the highest and safest in regards to getting the nuts fully threaded on. Also, you will be able to return to stock alignment specs as well, even with my 36" tires and 22" wheels, I am only .5 degrees off.
Pics for ya soon ahriman.
#110
and from the side after Nitrous Enterprise's 3/4" spacer up front (but on a slanted driveway):
#111
i think it looks better with the rear a bit higher. as you can see from my measurements, the rear on mine is almost exactly .5" higher ... and it looks nice that way i think, because of how the truck's body lines are shaped.
be careful with those rubber spacers ... sounds dangerous.
#112
#114
Here are the trimming pics...feel free to ask any and all questions. Hope you all are satisfied with your spacers.
Billy
trimming link
Billy
trimming link
#116
FYI-
You can run the rubber spacers within the system for sure. I can tell you that you are not going to gain more than 1/16" from them, but they do act as a decent isolator betweent the coil and lower revtek spacer. I have had them in the entire time.
Billy
Billy
#117
Billy
Billy
i am sure you guys got the joke, but i am not putting the rubber spacers back in to gain height, only to avoid any metal on metal squeaks later on...
the spacers worked out great. i put the entire lift in at once, so i do not have any b4 and after for the added gain from the spacer, but i am sure people will see the results that the nitrous spacer has on levelling our rigs compared to the stock rev spacer.
#118
wow, if that is all the trimming i will have to do, i will be a happy man! thanx for the pics.
Billy
#120
Originally Posted by SD4Runner
I've been too busy partying.... will update as soon as I install (tues/wed)
Damn you San Diego... heheh.
Billy
