York air compressor, 22RE
Old Sep 2, 2008 | 11:26 PM
Matt16's Avatar
Originally Posted by SwampThing
I wouldn't.
Well, maybe I would, but you shouldn't. Maybe you could get a pipe that has threads on both ends already so you can put a screw on cap, then you could weld the caps closed. But still, I wouldn't trust a pipe that's been welded on for anything that's going to be put under pressure.
The absolutely easiest thing would be to go and get yourself one of those mini 1-5gal propane tanks for like $5, and call it a day. They work great, I've used them many times before.
What's the difference between a bumper tapped for air and a homemade air tank?
Can you find a picture of a small propane cyl you're talking about?
Old Sep 2, 2008 | 11:42 PM
Matt16's Avatar
I wouldn't.
Old Sep 3, 2008 | 12:02 AM
SwampThing's Avatar
Well nothing I suppose, if you're not pressurizing too much. And you never know how much is too much.
And as far as the rollcage being filled with air, I'd be paranoid about one of the welds failing, say where your arm was resting, and that air shooting out at 150psi penetrates your arm and causes an pulmonary embolism, and you kill over. That would blow major gorilla balls.
Like the ones used for bbq pits.
Or you can use these
Hell, you could even use a fire extinguisher like this.
There's so many cheap and easy ways to make an air tank rather than jerry rigging something up that'll probably cost you more in material anyways.
Old Sep 3, 2008 | 08:05 AM
Matt16's Avatar
Won't those propane cans rust out from the inside when using them for compressed air?
Old Sep 3, 2008 | 07:14 PM
  #25
Matt16's Avatar
I went down to a used marine parts store and I found an old steel SCUBA tank as well as a pressurized aluminum kerosene tank.
The steel scuba tank is probably expired, and I don't know whether it will rust on the inside. I don't think I have to worry about the tank exploding on me as I'm using it for 150psi max, but I am worried about rust clogging the various valves. Also, finding fittings for a scuba tank might be difficult.
The kerosene tank is pretty old, but its aluminium, so it won't rust. I don't know if its NPT though (how do you tell?). It has 2 or 3 openings. The tank is about 3gal, which will be easier to mount above the rear axle.
Both are $20.
Old Sep 5, 2008 | 05:46 PM
  #26
Matt16's Avatar
I bought an air-brake tank, tapped for NPT already. It was $40.
Old Sep 11, 2008 | 08:17 PM
  #27
Matt16's Avatar
From the looks of it, the side of the York is going to contact (not fit) against the passengers side torsion bar end. Thats not even taking into account that the motor leans towards to passenger's side when its straining.
It looks like I may be designing my own bracket.
The bracket would work fine with a inch or two drivetrain lift, which I can't afford now.
Old Sep 11, 2008 | 08:25 PM
  #28
Jay351's Avatar
Damn, that sucks! I am very interested in the bracket you come up with
Old Sep 11, 2008 | 08:48 PM
  #29
Alex 400's Avatar
http://www.budbuilt.com/new/york_brackets.html
See if you can get them to help you out.
Old Sep 11, 2008 | 09:32 PM
  #30
Matt16's Avatar
I may be able to bend this one into the shape I want it yet. That will have to wait until friday or saturday though. Its going to be tight though, the York is a big unit.
Old Sep 12, 2008 | 10:06 PM
  #31
Matt16's Avatar
The first bracket it completely wrong. Right idea, the wrong dimensions though.
Old Sep 19, 2008 | 09:11 PM
  #32
Matt16's Avatar
Alright, bracket done, plumbing done, wiring done compressor mounted.
I HAVE ONBOARD AIR! And lots of it too. Fills up my 31x10.5r15 from 8psi to 30 in about a minute. Filled my 2.5 gal tank to 150psi in about 45 sec- the blowoff valve sounds wicked. Now there is a pressure switch as well- so I won't be hearing that anymore unfortunately. The compressor itself is super quiet- you can barely hear it above the engine noise at idle standing with the hood open. Makes sense, it used to be an AC compressor.
Now for 18 wheeler horns
Old Sep 19, 2008 | 09:53 PM
  #33
SwampThing's Avatar
Show you the setup on my dodge manana when it's light
Old Sep 24, 2008 | 03:41 PM
  #34
Matt16's Avatar
ITS FINISHED!
https://www.yotatech.com/forums/f116...mplete-155162/
  #35
Matt16's Avatar
Come on then, lets see.
Old Sep 24, 2008 | 04:05 PM
  #36
SwampThing's Avatar
Oh, completely forgot. Go out and take some pictures now
Old Sep 24, 2008 | 04:07 PM
  #37
Jay351's Avatar
Oh man, the big rig horns are the icing on the cake! Im very jelous now
Old Sep 24, 2008 | 04:12 PM
  #38
Matt16's Avatar
Air horns supplies. I might just go down to 99 Truck Parts by Scott Rd. and piece together a system.
Old Sep 24, 2008 | 04:26 PM
  #39
SwampThing's Avatar
Old Sep 24, 2008 | 04:31 PM
  #40
SwampThing's Avatar
I used to have dual bell 36/26" horns mounted up under the bumper, but that's just a horrible place to put horns sound wise, and I didn't really want to mount them on the roof. These 4bell siege's are super loud, and combined with the fact that they're pointed at the ground, they reflect off the pavement so they're not direction and they sound much much much louder than those longs ever could have.
