Wing window ?
some companies make replacements. Most glass companies would know where to find them.
If just your glass is broken, and the frame and seal are ok, just get a new one from the dealer. They are pretty cheap, plus they fit right the first time and seal correctly. Aftermarket glass for those wing windows is cheap, and doesn't always seal right.
From: Houston (home), Atlanta (school), Cincinnati (work)
they told you they couldnt get one? thats a bunch of crap. are you talking about the "ext. cab" window? the small one that pops out? mine was broken into the same way. i called about 7 local glass repair companies and they ALL had that window. ended up getting mine replaced for $150 installed at my place. its called the quarter glass/window.
I think he is talking about the wing window in the door. Some 89-95 trucks had those little triangle shaped wing windows. They stopped making that in 95 tho, and none of the Tacomas had that option.
PNW94Runner
Sep 29, 2015 02:55 PM
tazman1972
11
Sep 28, 2015 10:32 PM
They told me at my local dealer they couldnt get one
I will talk to Strap22. Thanks so much!!
