will my 3vze afm work on my new 22re?
Old Sep 24, 2009 | 08:13 AM
kenbo53's Avatar
just got an 87 xtra cab for a hundred bucks but the afm is missing. i got it to fire up dumping some gas down a vacuum and it sounded pretty rough so i was wondering if i could temporarily rig my 3vze afm on there to see how it runs befor i put any time or money into the motor.
Old Sep 24, 2009 | 08:35 AM
TNRabbit's Avatar
MIGHT work for starting it but certainly not for running it properly.
Old Sep 24, 2009 | 09:23 AM
olharleyman's Avatar
I have a 22re afm if you need one get hold off me
Old Sep 25, 2009 | 09:02 AM
kenbo53's Avatar
thanks for the help i didnt figure it would work good if it did work but the plug looks the same so mabey ill get time to try it out tommarow. and thanks olharleyman i might i really want to see if its worth any time or money tho first cuz ive got a low miles 20r that runs real good that im considering dropping in there
Old Sep 25, 2009 | 09:27 AM
Jay351's Avatar
Did you test the AFM?
Old Sep 25, 2009 | 11:30 AM
I have two so if you need one I will still have one just pm me if you do
Old Sep 26, 2009 | 10:06 AM
kenbo53's Avatar
it wasnt on there when i got the truck
Old Sep 26, 2009 | 05:21 PM
RX729's Avatar
I think he's asking if you tested the v6 afm on the 22re
Old Sep 27, 2009 | 05:49 PM
kenbo53's Avatar
tried it out tonight turns out it does not work but a 22re will somehow run with no afm at all. after messing around with it i found a blown fuse replaced that and now it will fire right up and idle but obviously the throttle response is horrible and itll cut out and die randomly but does run.
MMA_Alex
25
Apr 18, 2017 05:07 AM
colinmil
Jul 6, 2015 04:03 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
gog1968
Jun 22, 2015 05:55 AM
