why is my truck hard to start when in cold weather?
Old May 12, 2007 | 04:24 AM
NinjaWa's Avatar
Question why is my truck hard to start when in cold weather?
i got a 93 pickup with 22re motor and every morning i'm having a hard time startng the car but when in the afternoon when the weather is a little bit hot, it starts right up. so far i changed the distributor cap, rotor, plug wires, plugs, and oil. does anybody know what else should i check for because its really annoying in the morning when i have to crank it like 7-8 times in order for it to start. thanks in advance...
Old May 12, 2007 | 04:51 AM
thook's Avatar
Start with the cold start injector timing switch. If it's corroded, try cleaning it up first with some fine sandpaper. If that doesn't help you can bypass it easily. But, try cleaning it first.
Old May 12, 2007 | 05:11 AM
TNRabbit's Avatar
x2 on cold start injector issues; good place to start.
Old May 12, 2007 | 08:52 AM
Robrt32's Avatar
Mine is the same way, A little shot of starting fluid in the air filter box and it will crank right up.. Been cranking mine on cold mornings like that for 2 years.
Old May 12, 2007 | 07:47 PM
NinjaWa's Avatar
i'm sorry but where is the cold start injector timing switch at?
Old May 13, 2007 | 10:37 AM
thook's Avatar
There are two switches sticking out of the front of the motor more towards the passenger side. If you look down just below your top rad hose you'll see them.....one's green and the other's brown. The brown one on the left is the switch you want to look at. BUT, while you down there, pull the other one out and give it a good cleaning, also....if it has build up on it. That's your coolant temp sensor.
Old May 13, 2007 | 01:06 PM
Robrt32's Avatar
I just went out and looked at mine , right under the green plug there are 2 vacume lines right there ,1 on top of the other, well both of mine were not connected. Any idea what they do? It ran fine like it was but i guess they are there for a reason
Old May 13, 2007 | 01:34 PM
thook's Avatar
I believe it's for the timing switch, but I'm not sure. I forget what it's called, too. Time to look in the FSM....
Old May 14, 2007 | 02:06 AM
NinjaWa's Avatar
i took both of the switches out and gave it a light sand and put it back in, still the same. anymore suggestions?
Old May 14, 2007 | 02:13 AM
rocket's Avatar
Originally Posted by NinjaWa
...anymore suggestions?
Theres roughly 2 dozen threads about the same exact problem your having. I recommend using the advanced search option and start reading them. Theres a wealth of information here thats "hidden" but easily obtainable if you use the tools. Welcome to YT. I hope you get it fixed.
Team420
Jan 12, 2021 04:57 PM
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
JF9243176
Jun 24, 2015 04:53 AM
jmc88runner
Jun 18, 2015 03:39 PM
