Why is my cat sideways, and what is this button to
Old Nov 8, 2008 | 11:38 AM
SR5's Avatar
SR5
Im pretty sure it suppose to be flat up against the body
and what is this button, its on the bottom of my driver side dash, by my right knee
Old Nov 8, 2008 | 11:45 AM
myyota's Avatar
Your cat should be flat, but will work just fine the way it is, it was probably removed or possibly replaced and not put in flat for some reason, as for the button, no idea what its for, its not a stock button so you will need to follow the wires and see were it goes.
Old Nov 8, 2008 | 11:51 AM
littlecommando's Avatar
you could just push it, but that could be a bad idea
or, if you know the person you bought it from, just call and ask
Old Nov 8, 2008 | 11:54 AM
tampabayota's Avatar
just dont be sitting in the passenger seat when you press the button
Old Nov 8, 2008 | 11:59 AM
4Crawler's Avatar
Sometimes the cars were installed vertically like that at the factory. My buddy's '94 pickup was set up like that and when he had the exhaust replaced he had the shop cut and re-weld the cat mounting flanges to sit horizontal.
Old Nov 8, 2008 | 12:14 PM
iamsuperbleeder's Avatar
hahaha
when my buddy installed his long tube header, the flange on the end of it was clocked wrong, so the cat bolted up in the same way...
Old Nov 8, 2008 | 12:18 PM
thedude42's Avatar
no idea i have never seen anything like it be4
SR5's Avatar
SR5
i just dont wanna hang it up on a rock, so can i get a one of a junk yard one, or is it cheaper to cut it, and reweld it.
Old Nov 8, 2008 | 12:19 PM
SR5's Avatar
SR5
i have, hundreds of times, in various conditions and nothing
Old Nov 8, 2008 | 12:24 PM
85toy's Avatar
as ppl have said you could just cut and reweld you cat. and the best advice for the button was already posted, follow the wires.
Old Nov 8, 2008 | 03:27 PM
Elton's Avatar
is that a valet button for a car alarm ?
Old Nov 8, 2008 | 03:33 PM
wino$41's Avatar
From: spokane, wa (then), mesa, az(then) Eugene, OR(now)
The button is probably for your alarm system overide. It's a means of turning off your alarm after your key is in the ignition. It's usually preset so that you have to push it a specific # of times to cancel the alarm. All of this assuming you have an alarm, usually aftermarket. That's my guess anyways.
I8URSVT
Jun 21, 2016 01:31 PM
dzldust
7
Oct 6, 2015 05:39 AM
voiddweller
Sep 28, 2015 11:21 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
Keithstoyota
Sep 27, 2015 07:29 AM
