Who knew it was a stick???
Old Dec 18, 2009 | 12:55 PM
fierohink's Avatar
So I had to pull my crazy heavy trailer the other day and my normal puller, a '99 f-350SD, was out of commission waiting on some parts. So I figured I just hook up the ol' Yota and away I go.
As I said the trailer is a little heavy so I needed the low grunt of low range. Well wind up Lo 1-5, grab Hi and 3rd, 4th, then 5th. Who knew it was an 8 speed?
Old Dec 18, 2009 | 01:02 PM
shaeff's Avatar
How'd you change between lo gear and high while moving without killing your transfer case?
Old Dec 18, 2009 | 01:03 PM
93YotaMonster's Avatar
X2
Old Dec 18, 2009 | 01:31 PM
TOYOTA 1's Avatar
lol its easy, pull the lever down.
been doing it for years, just grinds a lil bit, nothing major.
you can go from low to high with out much trouble, just cant go from high to low
Old Dec 18, 2009 | 02:01 PM
4Crawler's Avatar
You can double (or triple) clutch to shift from low to high range. I do that from time to time, like in heavy stop-n-go traffic, low range makes it easier to creep along, but if all of a sudden traffic opens up and you are doing 30 or so, you can go up to high range by picking the closest gear there and rev matching before shifting the t-case. And you can go into low range on the move, but it takes a much more precise shift to get the revs right (t-case is non-synchromesh).
Old Dec 18, 2009 | 02:16 PM
fierohink's Avatar
Let's just say the eyes on the flagger at the construction site I had to drive passed were as big as dinner plates when he heard me pull out, shifting through 4 gears up to about 22mph.
And 4crawler is right , it all comes down to matching speeds, wound up 5Lo puts me just ahead of 3Hi. Get 5Lo, push clutch in, shift t-case to neutral, dump clutch, push clutch in and tach up, grab 3rd gear, dump clutch, push clutch in and tach up while pulling t-case lever to get Hi-Range, let the clutch out. It seems like a lot of work but to a guy that doubles in everything you really don't notice.
Old Dec 18, 2009 | 03:16 PM
BigBluePile's Avatar
lol! That's awesome!!
Old Dec 18, 2009 | 03:45 PM
RustBucket's Avatar
Very cool. Will have to try that sometime! I think I have a spare transfer case if my timing is off...
Old Dec 18, 2009 | 04:45 PM
fierohink's Avatar
Works best when you are really overloaded otherwise you wind up and down too quickly.
Old Dec 18, 2009 | 08:30 PM
shaeff's Avatar
Huh, never tried that. I'm very good at rev matching (and decent w/ heel/toe)- I'ma give it a whirl sometime soon.
Old Dec 19, 2009 | 06:25 AM
iamsuperbleeder's Avatar
geez, now you're going to me ME try this too, lol
might try to tow my father's boat or something
Old Dec 19, 2009 | 06:42 AM
Tofer's Avatar
Sponsor
i shift from 4 lo to 2 hi all the time.... i find that 4lo 3rd matches 2 hi 1st... i'll get to 3rd in 4lo, then shift to 2nd, and throw it into 2hi all at the same time.
Old Dec 19, 2009 | 08:09 AM
RustBucket's Avatar
Just tried it this morning - works great! The t-case was a touch notchy going from Lo to Hi but that's just because I'm a n00b
Old Dec 19, 2009 | 12:02 PM
rattlewagon's Avatar
with both my 4runner and my truck, i necer stop going from 4low to 4 hi. just push the clutch in and shift it as normal. but i always stop to go from 4hi to 4lo
Old Dec 21, 2009 | 01:52 AM
Blue Bowtie's Avatar
Cool, never thought of doing that.
Old Dec 21, 2009 | 10:54 AM
Stuwy123's Avatar
Neato. Gotta try that one.
I like using 4lo in traffic. Just idle along while everyone else with slushboxes drag their brakes.
Old Dec 21, 2009 | 01:05 PM
I was going to try this out today...
but I ended up not taking the ol girl to work... it was too cold to drive 40 minutes without a heater, lmao
Old Dec 22, 2009 | 07:29 PM
aviator's Avatar
I've had to do that kind of thing a couple of times pulling heavy trailers but usually just to get it rolling. The 4lo is great to use to get moving on icy roads/parking lots sometimes because it keeps the driveline turning slow enough the wheels don't break loose. A lot of fun but too much like work for an everyday thing.
Old Dec 23, 2009 | 09:08 AM
mmcpeck's Avatar
I use the 4Lo to get my boat up the ramp, creeps it up nice and easy with no beating on the clutch, I usually stop once up the ramp and switch back to 2Hi, but never thought of doing it while moving.
Might be stepping up to a 25' boat this winter, and was wondering how the hell I was going to trailer it with my 3.slow, not far, just a couple miles. Looks like this may be something to try.
So I can get some momentum with 4Lo and just pull it back into 4Hi once I get up to like 15-20mph, or to 2Hi?
Is there any gear reduction from 2Hi to 4Hi?
Old Dec 23, 2009 | 02:02 PM
the 38 special's Avatar
no, its 1:1, just engages or disengages the front prop shaft
